2007 F150 Lariat P0307 Error Code
Old Dec 31, 2013 | 10:59 PM
csocs_wolf's Avatar
csocs_wolf
My 2007 Ford F150 Lariat (5.4L) with 82k miles popped a P0307 (#7 misfire) code one chilly morning. It began stumbing and hesitating a bit between 25-35mph, and each time it occurred, the engine light would flash on and off. Hesitation clears and light goes steady. Cleared the code and didn't see problems again for a month...until the next cold day (freezing temps). Popped again and hesitation returned. Ford dealer wants $350+ to change plugs. I've read coils can also cause the issue. Not sure if I can do either myself. Any advice for best way to fix this without just throwing money and parts at the issue? Thank you.
Old Jan 1, 2014 | 09:04 AM
70f100longbed's Avatar
70f100longbed
You could just change the #7 plug and boot and see if it still skips. I doubt it's the coil itself, 3v coils are pretty tough but the boot could be bad if the spark is jumping outside the plug. That leaves carbon tracks and gives the spark somewhere easier to go than inside the cylinder. Your mileage is about average on a set of plugs before they start misfiring. $350 is not too bad of a price the plugs are $20-25 each so that leaves $180 for labor. Just ask them what the charge is for broken plugs. Any more than 1/2 hr labor per plug is too much. I don't charge any extra if only 1 plug breaks. Most techs have figured out how to get them out without breaking most of the time.
Old Jan 31, 2014 | 10:52 AM
csocs_wolf's Avatar
csocs_wolf
Resolved
I ended up buying the Lisle tool from Amazon ($58) just in case, along with 4 Motorcraft 515 plugs. I replaced plugs 5, 6, and 7. Starting with the one that was malfunctioning (7), I found it was barely hand tight. 5 and 6 took a lot to break loose, but were then fine. No screeching and none broke. Put nickel anti-seize on new plugs and dielectric on boot contact. All back together and problem is resolved - under an hour's work. Running much cleaner. I'll do the other 5 plugs later on down the road when I need to.
Old Feb 3, 2014 | 09:43 AM
csocs_wolf's Avatar
csocs_wolf
While it seemed to be OK initially, the first cold morning, it happened again. Wicked shimmy from the engine and missing. Engine light flashed, but was off by the time I got home. Couldn't get a reader on it. As the truck warmed up, problems went away. So I just ordered the other 4 plugs. Was hoping to wait until weather thawed and I had a warmer day to do it. But guess I'll have to do it in the cold. Still not sure what was going on, but hoping finishing the plugs off will correct it.
Old Mar 7, 2014 | 07:02 PM
csocs_wolf's Avatar
csocs_wolf
Finished the other 5 plugs. #4 was loose as well and the boot smelled burnt. So I replaced that too. Have driven a couple weeks now with no further problems. Glad it wasn't anything more serious. Thanks for the help.
FFEric
2004 - 2008 F150
26
Feb 20, 2022 07:56 AM
jmbobs
2009 - 2014 F150
Sep 11, 2017 07:52 AM
TomFL
Nov 4, 2014 09:10 AM
PEG
1997 - 2003 F150
Feb 21, 2011 06:02 PM
t_money662
Jun 26, 2006 07:08 PM
