disc brakes
Old Jun 25, 2003 | 10:04 PM
widowmakers20's Avatar
widowmakers20
disc brakes
on my 69 f-100 2wd what parts from other trucks could i use to get the truck switched over to disc brakes.
thanks
Old Jun 26, 2003 | 05:12 AM
stroker393's Avatar
stroker393
disc brakes
Log on to the tech article section located on the right hand side of your screen, scroll down to the 1997 articles and you will find all the info needed to convert to disc brakes.
Old Jun 26, 2003 | 09:58 AM
William's Avatar
William
disc brakes
All true but consider doing power brakes and steering at the same time. Best bet is buy another truck and move everything. I like 76-79 with the same engine as the target truck. It seems easy, just take a wheelbarrow, fill it up with parts at the Junk Yard and install all that stuff on your truck. NOT! If you have a parts truck you can take your time and clean, inspect, paint and rebuild all the stuff you will need. Then do the installation. It will take a few days of work but if everything is on site it usualy goes really well. Post back we like to hear how these projects go. We all were where you are at one time or another over the years. I am forgetting my manners, I'd like to say Welcome to FTE! This is the greatest site for Ford trucks.
Old Jun 26, 2003 | 11:18 AM
widowmakers20
disc brakes
thanks this info is exactly what i needed to do this.
Old Jun 27, 2003 | 05:26 AM
willowbilly3's Avatar
willowbilly3
disc brakes
I did one of these and it was one of the easier swaps on a Ford that I have done. The only part that wasn't a bolt on was the size of the flare nuts on the balance valve. We had to put on the larger ones which will require doube flaring them in some rather tight quarters.
