oil change schedule
Old Jan 21, 2014 | 03:01 PM
iggybob44's Avatar
iggybob44
Along with the oil changes, id suggest watching the charge state of the vehicles batteries, and add a fuel stabilizer..........deteriorating gasoline could be just as big a problem as oil, and couple mile drive may not keep your battery properly charged, especially if a sitting vehicle doesnt start right away after sitting
Old Jan 21, 2014 | 04:16 PM
CB3's Avatar
CB3
oil change schedule
Thanks to all of you for the info and opinions.
CB3
Old Jan 22, 2014 | 11:22 AM
VocaTexas's Avatar
VocaTexas
I worked for a Texaco oil distributor for ten years, that's been nearly twenty years ago, but here's my opinion:
I put only about 3000 miles a year on my pick ups. I change the oil at around 3000 miles in them. My driving consists of a lot of very slow driving on the ranch, a few trips into town a month, and a bit of towing heavy loads on the highway. It gets a lot hotter in central Texas than it does in Tennessee, so I run 20W50 in my dentsides. Anything else gets as thin as water in the summer time. In Tennessee, you would probably be fine with 10W30 or 10W40. I personally use Havoline, but Shell, Exxon, or Chevron Delo would all be good choices. I will not use Quaker State or Pennzoil. I have seen engines with tons of sludge in engines that did use those.
For an oil filter I run NAPA Gold 1515 oil filters. They are the same as the Wix filters, but cost less.
My '79 had around 86,000 miles on it when I bought it, and the previous owner had run Havoline oil in it. I put a long-block in at 187,000 miles. I'm at nearly 250k now, so what I'm doing must work, at least for me.
Old Jan 22, 2014 | 01:15 PM
iggybob44's Avatar
iggybob44
Good detailed info Voca! you detail your driving habits, what you use and why........Sounds logical and you mention geography and climate, both important factors!
Truckpilot1329
2009 - 2014 F150
55
Dec 19, 2019 07:37 PM
wolf189
2004 - 2008 F150
Jan 30, 2011 06:54 PM
Jam3z
2004 - 2008 F150
Apr 4, 2008 01:23 PM
Randy777
Dec 10, 2006 07:32 PM
hlozano
Modular V10 (6.8l)
Dec 12, 2005 09:18 PM
