No start, CKP sensor 12v source?
Old Dec 30, 2013 | 09:19 PM
churchkey's Avatar
churchkey
Hi Guys, 2000 Expy 4.6 no start problem, no CEL.
Fuel pressure checked first its 36#. New pump & filter installed 5K miles ago.
Checking circuits following the Haynes manual, all is well until I get to the crank position sensor. Haynes wants 12v on one lead, I don't have it. The manual does not state the 12v source however looking at the wiring diagrams 12v for the CKP sensor seems to originate in the PCM.
PCM relay is functioning, fuses are good.
CKP sensor wires were hacked under the AC compressor, fixed that with a new plug/wires & threw a new CKP sensor in. Found another CKP wire hack job at the front corner of the valve cover. Wires twisted together & a glob of tape. Did not reconnect those wires yet but tested for voltage to them KOEO I get 1.56V on each wire no 12v.
I think I need a new PCM if I have the 12v source identified correctly.
What say the Ford Gurus?
Thanks for looking.
Old Dec 30, 2013 | 10:10 PM
alloro's Avatar
alloro
Here is a PDF of the wiring diagram to the CKP, along with the pinpoint tests.
File Type: pdf
Old Dec 30, 2013 | 10:43 PM
pdqford's Avatar
pdqford
A TWO wire CKP does not use an external power source. It gets its power from the movement of the reluctor teeth passing near the magnet.
You can put your DVM on AC volts and put one probe on each wire (Polarity is not an issue.) When the engine cranks over you will see a small AC voltage if all is well. The faster the engine spins the higher the voltage. (The PCM is really looking at the Hz.)
Following alloro'a pin point test () will let you know if there is an issue with the hacked wiring.
Old Dec 31, 2013 | 09:46 AM
churchkey's Avatar
churchkey
Thanks guys I'll work on it later today & post results.
Introducing 12v DC into an AC circuit made zero sense to me. If the Hanes manual is incorrect on this issue one has to wonder if there is other miss information.
Old Jan 1, 2014 | 02:11 PM
alloro's Avatar
alloro
For those of us that have been around a while, that goes without saying.
Old Jan 2, 2014 | 10:17 PM
churchkey's Avatar
churchkey
Update: I have an AC signal from the CKP to the PCM, 12v in & out of the coils but no trigger signal to fire any of the coils.
Looks like PCM time.
Thanks again for the help guys & Happy New Year.
nothingbutford
1983 - 2012 Ranger & B-Series
Oct 17, 2024 07:44 PM
IHateCommieCars
Feb 2, 2021 08:08 AM
nd48463
15
Aug 3, 2018 07:57 AM
tmill28
Oct 19, 2017 04:56 AM
Lsvare
Sep 11, 2015 11:43 PM
