My dually conversion, with some porn..
  #106
Old 01-11-2014, 04:28 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
Honestly Rick, haven't even started it yet with the 5 inch. I wanted to get the box and axle done, truck set down, then make sure the exhaust was mounted to clear everything ok. It's more/less last on my list. It was much easier to hang it with the box off, but I'll finish it at the end. I don't have any clamps or anything on it yet.
Thanks Nate!
  #107
Old 01-11-2014, 04:36 PM
427 fordman
Somebody got a link to some good body bushings? I thought I had something saved, but guess I don't.
Glenn, I know you had a couple links saved for replacing them too, would you mind putting them up?
I did a search, but almost everything was in umpteen page threads, and I didn't want to look through that much.
  #108
Old 01-11-2014, 05:11 PM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
I got the ones I bought (the ones Glenn ended up using) from Jeff's Bronco Graveyard. Here's the link:
Black
or Red
  #109
Old 01-11-2014, 07:47 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
  #110
Old 01-12-2014, 05:46 AM
427 fordman
Thanks Glenn and Nate. I'll get a set ordered today.
  #111
Old 01-12-2014, 11:34 AM
427 fordman
Glenn, I don't remember, did you find one way that worked best to remove the old ones?
I pulled the front apart this morning and switched bearings and races over to the dually hubs. I have to get some bolts to put the brake rotors on them. R&R rest of the day.
  #112
Old 01-12-2014, 12:01 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Looking good Darin. Hope everything goes well with the Doc. Take it easy and don't over do it.
  #113
Old 01-12-2014, 01:58 PM
427 fordman
Thanks Bill. I hope it goes well too.
  #114
Old 01-12-2014, 06:26 PM
oldbird1965
The directions from the factory said to use a piece of muffler pipe as a puller. Didn't work for me. Another said to drill them out but I couldn't see doing that. Then I read the one I did and it worked great. Lope a chain under a floor jack and use the bolt that you took out and put it thru a couple links of the chain. Screw it into the bottom threads with the chain fairly tight, then jack up on the frame, it will pull it right out. I say right out, LOL. Some of them were really in there and I couldn't believe the pressure I had to put on the jack before they popped out. Clear as mud?
  #115
Old 01-12-2014, 06:41 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
You didn't get the bolts with your dually hubs?
  #116
Old 01-13-2014, 05:33 AM
427 fordman
No, I bought them from someone on here and they weren't with them. There isn't anything special about them, is there? I had a 9/16 bolt with a shoulder/thick washer on it that fit well, so was going to look for 16 like it. Was thinking I'd loctite them in and be good.
Glenn, I think I got what you are saying. I'm gonna tackle this before I do any more work on the box in case I need to shim it to make the body lines line up.
  #117
Old 01-13-2014, 08:19 AM
oldbird1965
My body lines ended up with the cab higher but was told it would settle?
  #118
Old 01-13-2014, 06:05 PM
427 fordman
I don't think the poly will settle much at all. Maybe I'm off base, but I'm going to set it up so the box is pretty much the same as the cab.
Someone set me straight if I am wrong.
  #119
Old 01-13-2014, 08:11 PM
oldbird1965
I think your thinking is correct. Do the body then shim the bed to match.
  #120
Old 01-14-2014, 02:00 AM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Thats gonna be one heck of a towing rig this summer Darin. Hope it all turns out the way you want it. At least till next winter haha.
Quick Reply: My dually conversion, with some porn..
