My dually conversion, with some porn..
Old 01-01-2014, 03:45 PM
427 fordman's Avatar
427 fordman
427 fordman is online now
It's a fold down type Tom, that folds down side to side. It's getting pretty worn, as when its up it has quite a bit of play forward and backward. I'm gonna pick up a piece of 1/2 x 6 x 8 plate to put between the 3/4 steel braces on the truck now. I'll weld it to them, and put some extra support underneath to tie the plate and cross braces together. I got a solid ball with a safety chain hookup on it with the bed so I'm going to use it. Blow a hole in the plate and be good. I'm going to weld the nut to the bottom of the plate when I get the ball tight into place. My fold down ball NEVER got folded down anyway.
  #32
Old 01-01-2014, 04:02 PM
427 fordman
Got the dp built and the exhaust hung today. It's all done except I didn't clamp anything together yet. I will do that after I get the box and axle back on. Make sure on clearances, etc. Lots of time into that thing, but now I have a nice big downpipe, and will not have to worry about any rubbing when I get done. I think it was worth it, but it was a lot of climbing around, hooking up and removing the dp more times than I can count, etc.
Here's a few pictures. I didn't take any from underneath, but at the end of the dp is the 4-5 inch adapter, then a 30* 5 inch angle pipe, then it adapts to the 5 inch system.
First shot is my hole. I made it a little wide, but made things a little easier. Doesn't really matter, just a little bigger patch piece.
Here's one top view shot. I've got a good 1/4 inch clearance from hitting anywhere. That will be plenty.
One last shot of the old one and the new one side by side.
I may have a little time the next couple days before the weekend to finish the floor. I'd like to get that wrapped up, then do the rear end this weekend. We'll see how things go.
  #33
Old 01-01-2014, 04:54 PM
martin72's Avatar
martin72
martin72 is offline
Looks good Darin.
  #34
Old 01-01-2014, 07:02 PM
fordman67's Avatar
fordman67
fordman67 is offline
Nice sewer pipe man!!!!
  #35
Old 01-01-2014, 07:45 PM
dougbrown's Avatar
dougbrown
dougbrown is offline
Looking good. I'd recommend that when u put the rest of the exhaust in you use the band type clamps over the round u type ones. Make it nice to get a part when there a problem later down the road.
  #36
Old 01-01-2014, 07:49 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Wholly crap Darin, I'm impressed!! As much trouble that I had with just a 3 inch, I should have gutted the firewall like you did. Oh well, give me something to do next winter, right? LOL Of course, I'll need up dates thru the summer in how that works! When we convoy to RRE you will blow my doors off.
  #37
Old 01-01-2014, 07:52 PM
oldbird1965
X2 a thousand times over. It was a PITA getting mine apart and I put it back together with band clamps.
  #38
Old 01-01-2014, 08:03 PM
fordman67's Avatar
fordman67
Rre for the win!!!!
  #39
Old 01-01-2014, 08:12 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
The convoy is getting bigger!!
  #40
Old 01-01-2014, 08:14 PM
dougbrown's Avatar
dougbrown
  #41
Old 01-01-2014, 09:07 PM
fordman67's Avatar
fordman67
gonna take that mother over!!
  #42
Old 01-01-2014, 09:09 PM
oldbird1965
Summit racing are the cheapest ones I found, if you can wait.
  #43
Old 01-01-2014, 09:42 PM
fordpride's Avatar
fordpride
fordpride is offline
Looks good Darin
  #44
Old 01-02-2014, 05:08 AM
BEEMAC's Avatar
BEEMAC
BEEMAC is offline
Originally Posted by farmert
What do you mean by shorter? Closer together? If so you got a cab and chassis rear axle. You need an axle from a truck that left the factory with a bed installed. Look at this thread for measurments. https://www.ford-trucks.com/forums/1...l#post13216938
Tom, Darin; Thanks for the info. Greatly appreciated. I will have to look at what I have on my current F250. Im sure it had a regular bed on it, but it has a flatbed now. BTW that F250 has 408,000 miles on it. 130,000 put on personally by me. What a truck.
Darin all is looking awesome.
  #45
Old 01-02-2014, 05:22 AM
427 fordman
Thanks a lot all you guys! I bought a few new band clamps, so I should have enough to complete it when I'm ready.
As far as RRE, sorry, but its not gonna happen. My penny saving is going to have to go to a paint job on the box, plus my uncle is dropping off a 598cu in. motor at my shop I have to figure out how to buy from him...
Quick Reply: My dually conversion, with some porn..
