Sponsored by: Real Truck
problems with 4x4
Old Dec 30, 2013 | 05:57 PM
powerstrokin111's Avatar
powerstrokin111
problems with 4x4
Hey guys im new here and apologize if this is in the wrong spot. My issue is my 4x4 will not ingage. the light comes on but that is about it. I took of my center rim caps and tried putting them in manual instead of auto to see if that would help but nothing. Any ideas would be greatly appreciated. Thanx a bunch.
Old Dec 30, 2013 | 07:44 PM
tgreening's Avatar
tgreening
Hey guy, would love to help but things like year, model, engine, tranny, etc etc would most likely be some useful information.
Old Dec 30, 2013 | 08:29 PM
powerstrokin111
Ya i guess it would. sry im a noob. Its a 99 F250 7.3 powerstroke. Not sure about the tranny, what ever came in them stock.
Old Dec 30, 2013 | 09:29 PM
SC_Hoaty's Avatar
SC_Hoaty
Tell me about your 99. Does it have the lever on the floor, or the **** on the dash (to shift to 4x4)?
Does 4WD LOW work? You can feel the difference in speed vs rpms. Even if only the rear wheels are turning, it would say the transfer case shift motor is doing its thing.
Your hubs - are the two positions "free" and "locked" or "auto" and "locked"? - What I'm asking is do you have auto hubs for shift-on-the-fly or a pure manual system?
When you tried rotating the **** on the hubs - it should be close to a full quarter turn. One truck I looked at was so stiff it took tools to engage it. When the hubs work right, it is no sweat for my wife to do it by hand. How were yours?
All these should help zero in on the problem.
Thanks!
Old Dec 30, 2013 | 10:32 PM
powerstrokin111
Thanks!
No low does not seem to work ether. the 2 positions are auto and and lock. They turn very easy and seem to even kinda click into place. It is a small switch by the steering wheel that ingages the 4x4. it is switch on the fly. one day it worked and one day i went out and it just didnt. No sign what so ever of going out or anything.
Old Dec 31, 2013 | 05:15 PM
SC_Hoaty's Avatar
SC_Hoaty
Might be the relays. IIRC there are two, so you can swap them and see if it will go into 4x4 and then fail to come out. Swap back to cure it if that happens.
It sounds like the transfer case motor is not shifting if it won't creep in low.
With the auto-hubs, some times pneumatic leaks develop, but manually locking them would still work.
Hope it is the relays, as they are cheaper than the motor!
Old Dec 31, 2013 | 07:16 PM
senix's Avatar
senix
to further narrow down the issue you could manually turn the hubs to lock. Then if you crawl under the truck the front drive shaft should not move.
Same if you turn the switch on the dash.
The transfer case has its own shifting motor.
So if the hubs lock and the drive shaft is locked in but no 4x4 then either the shift motor or the relays.
Old Jan 1, 2014 | 02:37 PM
powerstrokin111
Ok thanx a lot for the replies guys. Where would i find the relays at? Would they be under the hood?
Old Jan 1, 2014 | 07:03 PM
SC_Hoaty's Avatar
SC_Hoaty
See this thread (it has a picture) and see if your relays are in a similar location.
https://www.ford-trucks.com/forums/8...se-relays.html
_red rocket_
Dec 17, 2007 10:28 PM
96ford4x4turbodiesel
Jul 3, 2004 05:13 PM
Vaccuum
Oct 5, 2001 10:19 AM
monza
Aug 24, 2001 08:47 PM
