Starter???
Old Dec 30, 2013 | 10:14 AM
markbntx's Avatar
markbntx
Starter???
I have a 2010 F150 with 39,000 miles. This morning the truck started fine. I ran in to get something came back out and the truck had died. I tried to restart it and nothing. When you turn the key forward the starter spins and wont stop until u turn the key off. The truck never tried to fire. The motor tuned over and over but nothing. is there a starter relay? A solenoid? Can anyone help. I am lost on this one
Old Dec 30, 2013 | 11:10 AM
Turbo Dog's Avatar
Turbo Dog
The key switch only sends a signal to the ecm. Once the ecm gets the signal from the key it engages the starter. It continues to keep the starter engaged until it detects a running engine. Since your engine doesn't start the ecm keeps cranking.
Your problem isn't with your starter, you have a problem with either the fuel system or the ignition.
Check the easy things first...I once helped an engineer figure out why he couldn't start his jeep - it was out of gas.
Old Dec 30, 2013 | 06:17 PM
tvsjr's Avatar
tvsjr
The Dog is correct... you have a problem with fuel or ignition, or with a sensor or PCM not detecting all the right things to allow the motor to start. How much gas does the gauge currently show?
Csilcox
2009 - 2014 F150
Feb 25, 2017 10:05 AM
Roller150
20
Aug 4, 2015 10:28 PM
hornsurgeon
1997 - 2003 F150
Dec 3, 2012 07:34 AM
Bundy4825
17
Dec 10, 2011 10:11 PM
ridecolby
Aug 11, 2009 07:51 PM
