Spark plugs?
Old Dec 30, 2013 | 07:40 AM
DBLX's Avatar
DBLX
Question Spark plugs?
I'm getting ready to change the plugs on 09 F150 5.4. Should I have the same spark plugs concerns as the previous years? Was this corrected after 08?
Tia,
MJ
Old Dec 30, 2013 | 07:53 AM
Trailblazen's Avatar
Trailblazen
I want to say they were corrected with the 09+ models. My 2005 had 3 break off at the stealership but they drilled em out and put the new 100K plugs in. From what i have researched is that the problem was corrected with the redesign in 2009 but can't find "how" it was fixed
Old Dec 30, 2013 | 08:54 AM
Robbgt's Avatar
Robbgt
I can't comment on the year that the problem was addressed, however here is the tool recommended to remove any broken spark plugs from the 5.4:
Amazon.com: Lisle (LIS65600) Broken Spark Plug Remover for Ford Triton 3 Valve Engines: Automotive Amazon.com: Lisle (LIS65600) Broken Spark Plug Remover for Ford Triton 3 Valve Engines: Automotive
EDIT: Here is a TSB, looks like 04-05 http://www.etoolcart.com/06152.pdf
Old Dec 30, 2013 | 09:09 AM
Papa Tiger's Avatar
Papa Tiger
The spark plug design was changed. Use care, be prepaired, have the tool available. Have another vehicle ready. U start the job, U may screw up ur truck.
Old Dec 30, 2013 | 09:47 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Search found this, hope it helps
https://www.ford-trucks.com/forums/1...9-f-150-a.html
Old Dec 30, 2013 | 09:58 AM
Tom's Avatar
Tom
There is absolutely no reason for for the OP to have that tool on hand. That's like having having a distributor wrench to change a COP. The parts are different and this tool is just not useful on an '09 because the plugs are one piece and will not break
Old Dec 30, 2013 | 11:15 PM
DBLX's Avatar
DBLX
So I have no worries? Proceed like a normal spark plug change?
Old Dec 31, 2013 | 07:53 AM
msgtord's Avatar
msgtord
How many miles on your truck?
Old Dec 31, 2013 | 08:08 AM
Tom's Avatar
Tom
Sort of. To most people a "normal" spark plug change involves unplugging a spark plug wire and then going for the plug. These engines use Coil on Plugs(COPs) on each plug. So you'll need a little ~7-8mm socket if I remember right to remove the hold-down bolt for the coil. Remove that, pull the plug off, and you'll have access to the plug. It should come out without difficulty.
Your truck has aluminum heads, which means that proper torque is vitally important. These heads aren't as finicky as the ones used in the early 2000's that would eject the spark plug if not torqued exactly right, but you DON'T want to strip your threads. From what I can dig up online these have the same spec my old Excursion did which is 10-15 ft-lbs of torque. While you're in there I'd recommend changing out your spark plug boots. It's the equivalent of a plug wire change for a COP-equipped engine. They can be had cheaply from RockAuto, and they just slide off the COP. Over time the rubber wears, cracks form, and can short to ground causing a misfire.
So other than that, yeah, it's just like any other plug change.
Old Dec 31, 2013 | 03:51 PM
DBLX's Avatar
DBLX
My truck has 84k miles. I understand the requirement for the plug change in regards to the cop. I went through the horror with broken plugs with my previous ford f150. Some may remember my post years ago. I'm glad the plugs have been changed!
Old Dec 31, 2013 | 05:39 PM
marksp's Avatar
marksp
I have been an ASE double master auto/truck tech for 27 years....that problem has been corrected on 09 MY trucks so you can change your plugs without any concern...be sure to use a SMALL dab of anti-seize when u install the new plugs and save yourself a possible driveability concern and use OEM Motorcraft plugs. Any company stating their "improved" plugs give you better performance or gas mileage is selling snake oil. I cant begin to tell you how many check engine lights or driveability concerns are caused by using different plugs.
Old Dec 31, 2013 | 06:05 PM
DBLX's Avatar
DBLX
So stay with the stock plugs? I was planning on using a different brand... I'll follow your recommendation.
Old Dec 31, 2013 | 06:54 PM
marksp's Avatar
marksp
Yes, stick with OEM stock plugs. I have seen something as simple as putting Champion or E3 plugs in certain Ford vehicles cause a multitude of problems. My neighbor installed E3 plugs in his Ranger and had a massive hesitation on clutch release. After spending countless dollars at the dealer I told him to install a set of Motorcraft plugs and needless to say his problem was gone. I am no engineer and I cant say why that was but all my 27 years as an auto tech is worth something sometimes.
Old Dec 31, 2013 | 09:16 PM
awq134's Avatar
awq134
I'm glad i happened to look through this thread. I plan on inspecting/ changing my plugs in about 10,000 miles, when i hit 60,000 total miles. I was going to go with a set of autolite plugs that were comparably priced. However, i suppose there's a reason ford uses the plugs they use. They have worked so for in the truck, so i'm sure a new set of the same will work just as well.
Old Jan 15, 2014 | 05:37 PM
jeff keyuk's Avatar
jeff keyuk
I just change my plugs with no troubles!
1st start with a cold motor.
2nd blow out with air hose to clean out dirt.
3rd spray some wd40.
then turn out plugs slow,wd40 runs down on threads.
Plugs came out with no troubles.
