300 six runs warm
Old Jun 25, 2003 | 08:24 PM
chzuck's Avatar
chzuck
300 six runs warm
I have a 1985 F150 with a 300 six and manual OD transmission. Ever since I have owned it, it runs warm (3/4 of the way over on the gauge) once the outside temperature is above 50 degrees F.
I have tried several different brands of thermostats (195 degree), I recently had the radiator cleaned, I replaced the fan clutch. All this made no difference. It has never gotten to the H area on the gauge. Usually my vehicles run the same temperature winter and summer (according to the TEMP gauge). The fellow at the radiator shop that worked on my radiator said he had a 85 F-150 with the 300 six and his temp ran in the center of the gauge. Has anyone had similar experiences with this engine?
Old Jun 25, 2003 | 09:01 PM
Franklin2's Avatar
Franklin2
300 six runs warm
Don't rely on factory guages. You can waste a lot of money that way sometimes.
Old Jun 26, 2003 | 01:39 PM
brown 4x4's Avatar
brown 4x4
300 six runs warm
You could try a new sending unit. It screws into the block on the passenger side toward the rear of the head. My temperature guage is fairly accurate and never goes any farther than right at the middle.
Old Jun 26, 2003 | 04:10 PM
85F_150driver's Avatar
85F_150driver
300 six runs warm
you could try running a cooler thermostat. I think mine has a 180 and it only goes up when i am ideling for extended time. When i start movieng it goes back down to between the o and the n in normal. Might wanna try that.
Ben
Old Jun 27, 2003 | 12:58 AM
Hillbillywagon's Avatar
Hillbillywagon
300 six runs warm
The stock guage is no where near calabrated. If you are worried about it I would recomend adding a good aftermarket guage. Much more accurate.
Old Jun 28, 2003 | 10:20 PM
dffcvv1510's Avatar
dffcvv1510
300 six runs warm
mine does the same thing.When you turn it off you can hear hissing form a hoes from the radiator does yours have an overflow tank. good luck
Old Jul 1, 2003 | 12:18 PM
chzuck's Avatar
chzuck
300 six runs warm
Thanks for all who responded to my "running warm" question. It always is helpful to have experienced people make suggestions.
Old Jul 1, 2003 | 10:30 PM
bigreave's Avatar
bigreave
300 six runs warm
my 85 runs cold all the time unless you sit and idile and then it goes to 1/4 of the way till you start moving and goes back down. But mine has a radiator from 400.
Old Jul 2, 2003 | 01:47 AM
andym's Avatar
andym
300 six runs warm
The size of the radiator doesn't control the engine temperature (unless it's not getting enough air flow) the thermostat does.
The factory temp gauges aren't even consistent from truck to truck. If you want to know what your coolant temp is, buy an aftermarket setup.
Old Jul 10, 2003 | 12:51 AM
badeep's Avatar
badeep
300 six runs warm
How about the CAT?, there were two on mine, one had completely collapsed inside and the emissions were having a great time in the pipe just getting hotter and hotter!. Had an aftermarket fitted, now have only one instead of two and it sailed through the emissions test.
fordsuperduty250
Aug 8, 2012 09:01 PM
johnnyneutrino
Sep 20, 2010 02:59 PM
proteks
17
Dec 14, 2004 12:35 PM
lg300
21
Jan 7, 2002 08:36 PM
