power steering system flush/refill
Old Dec 29, 2013 | 10:13 AM
70-360fe's Avatar
70-360fe
Few months ago I replaced my steering gear box and since have not been able to get all the air out of the system. Got lucky, came from JY but works great except squeals gets a little hard on a hard turn. Researched and read about a few different methods just wanted to get some ideas from people on the board.
The pump is about 1.5 years old but did run dry for a day but I don't think bearing is bad. If I do have to replace pump I'am thinking a saginaw swap so if you have any links/info on swap let me know. Squeal is get on my nerve's a little. Thanks.
Old Dec 29, 2013 | 10:44 AM
HIO Silver's Avatar
HIO Silver
I don't have any particular recommendations on your current situation except to keep at it. FTE guy Earthquake resorted to flipping the steering box and eventually got all the air out.
In terms of going with a Saginaw PS pump, I've already got the parts to do swap on my '73 because its Ford pump seems not to put out enough pressure at idle... the RPMs have to come up before it has "full" power steering. Picked up CVF Racing's billet Saginaw-to-FE brackets and sourced the pump with a stud on the back from a 4WD '76 GMC Jimmy. I understand it's better to get the pump from a similar vehicle cuz the valving is already calibrated for the weight.
Old Dec 29, 2013 | 11:07 AM
70-360fe's Avatar
70-360fe
I think I might have read that thread, he had a 78-79 truck where hoses are hooked on the bottom? All swaps I've read about where being done on 80-90's truck's. Any suggestions about flushing/refilling system, looked at some online just want to get some real world methods/ideas.
Would like to keep this system if I can get the air out.
Old Dec 30, 2013 | 01:51 PM
JEFFFAFA's Avatar
JEFFFAFA
I have heard of guys using a vacuum pump. Cork (or whatever) in the pump where the cap goes. Drill a hole in the middle of it and push in a tube. Attach the hand held vacuum pump to that tube. Apply vacuum. I don't know if you're supposed to run the engine and steer lock to lock or not but I know they kept the vacuum applied for a couple of hours. And it worked. Good Luck.
Old Dec 30, 2013 | 04:20 PM
jowilker's Avatar
jowilker
70, Give this a try, raise the front wheels off the ground then turn the steering wheel coast to coast about 20 times. Should you then need to add any fluid add, Lucas power steering stop leak.
Should resolve your issue.
John
Old Dec 30, 2013 | 10:19 PM
70-360fe's Avatar
70-360fe
Found this video this morning.
Was going to try it this morning but it turned out my mity vac is not so mighty. Bought it a year ago and only used it a few times, hardly any vacuum-leaked. I took it apart and tried sealing it, have to try it again Wednesday as I'am busy tomorrow. There is a seal rebuilt kit I'am going to order. Looks to be a good method.
John I have tried the jack up and turn method, must have turned the wheel about 60 times. Helped but seems like there is a bubble trapped some where. Going down the road it's fine, get into a harder turn like at the gas station squeals and gets hard to turn. Been living with this for about 2 months I guess a few more days won't matter.
Flushing, I read a method where the return line gets disconnected and hose put into a container. Start truck and have another person pour new fluid in till clean fluid comes out. Stop truck, hook up return hose, refill and bleed. Like to try both methods back to back once I get a working vac pump.
Still looking at any ideas, especially if a vac pump is not involved. Like to get air out as soon as I can. Thanks!
Old Dec 30, 2013 | 10:50 PM
70-360fe's Avatar
70-360fe
Here is another video. Where could I hook up vac line, tran.s vac. modular connection?
Ok can't get the video to copy and paste, here is what they do. Use same method as above video except they connect tube end to a vac source on the engine instead of a vac pump. Where be a good source on engine for a vac source that would not be to high to damage pump. Thanks!
Here we go.
www.youtube.com/watch?v=egzQYcxaPGU‎
Old Dec 31, 2013 | 03:43 AM
jowilker's Avatar
jowilker
I suspect you have another issue then. Turning the wheel will usually remove air bubbles.
John
Old Dec 31, 2013 | 09:09 AM
70-360fe's Avatar
70-360fe
[QUOTE=jowilker;13897889]I suspect you have another issue then. Turning the wheel will usually remove air bubbles.
John [/QUOTE
I did run it dry for a short time so could be a pump issue. I'am hoping not the bearing is not a making noise. I've read where others had a hard time and I did replace the gear box so maybe air bubble. Anyway I will have to look at it tomorrow and see what happens.
I'll have to see if I can find any leaks also.
Old Dec 31, 2013 | 04:34 PM
jowilker's Avatar
jowilker
I have had to replace the lower seals in the gear but nothing else. Turning the wheels purges air from the system.
I usually don't mention those products, but the Lucus is awesome.
John
Old Dec 31, 2013 | 05:27 PM
JEFFFAFA's Avatar
JEFFFAFA
John
2X John on the Lucas products.
Old Dec 31, 2013 | 06:16 PM
70-360fe's Avatar
70-360fe
John
Replace seals 2 time's in just over a year, 2nd time it still leaked. Called and e-mailed redhead with no respond so hit the j/k and found a good one on an f-250.
Anyway if john (Old School) recommends something it's got to be good. It will be a couple of days before I get back to it. I will try the lucus and let you know how it goes.
BstangBill
Nov 18, 2018 10:38 AM
crazy96863
General Automotive Discussion
Feb 8, 2013 05:15 PM
dcassidy
Sep 17, 2009 09:11 PM
welder79
16
Mar 30, 2009 08:43 AM
Lane Dexter
Oct 3, 2004 11:52 PM
