head torque value
Old Dec 28, 2013 | 05:32 PM
pbc64's Avatar
pbc64
head torque value
hello I am missing my manual need to know the torque value on the head bolts 99 ranger 3.0 flex thanks paul
Old Dec 28, 2013 | 09:31 PM
Hank85713's Avatar
Hank85713
go to autozone.com they have links to repair guides, or try the ranger station under tech support.
Old Dec 28, 2013 | 10:11 PM
pbc64's Avatar
pbc64
torque values
thanks called someone got the torque settings heads are on
Old Dec 29, 2013 | 01:48 PM
pawpaw's Avatar
pawpaw
There are threads in the "Tech Info" thread atop this forum with photos & other details on the 3.0L that are a good reference.
Old Jan 2, 2014 | 11:24 AM
g_k50's Avatar
g_k50
Here's the install the bolts sequence from the 1999 Ranger Service Manual.
Install the bolts. Tighten the bolts in five stages in the sequence shown.
1. Stage 1: Tighten to 50Nm (37 lb-ft).
2. Stage 2: Losen the bolts one full turn.
3. Stage 3: Tighten to 30Nm (22 lb=ft).
4. Stage 4: Rotate 90 degrees.
5. Stage 5: Rotate an additional 90 degrees.
and there's a illustration of the sequence, there are 8 bolts, four across the top and 4 across the bottom.
1 is the third from the front on the bottom.
2 is the 2nd from the front on the top.
3 is the 2nd from the front on the bottom.
4 is the third from the front on the top.
5 is the 4th from the front on the bottom
6 is the 4th from the front on the top.
7 is the front bolt on the bottom.
8 is the front bolt on the top.
Good Luck and Happy New Year.
Action4478
Jun 12, 2008 07:22 PM
John - NNY
Flathead V8 & Flathead 6
Apr 26, 2006 08:55 AM
Gooch
1978 - 1996 Big Bronco
Feb 6, 2004 07:36 PM
straight_6
Apr 21, 2003 12:39 PM
thelonerangerxlt
Jun 1, 2001 11:09 PM
