1982 F250 Restoration just started - now with pics!
Old 12-29-2013, 12:11 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Originally Posted by FXDawg
they're both great trucks! that 74 is a beaut!
Thanks! The 74 was the only truck dad ever bought new, and the 2nd truck he owned in my lifetime. I was 9 when he brought it home. I *almost* got it when I turned 16, but he decided to keep it, just no one expected him to keep it another 30 years........ He did build a GT390 spec engine, and beefed up the C6, but the truck has seen well over 500K total miles. 200K of those, it ran on LP. Wish that system was still around..... It came off when the hotter 390 went it.
The 80 F150 I bought in 97. Very little has changed on it since then. At least, not what anyone would notice.... I've certainly gotten my $1500 worth out of it.
I plan to swap the 300 & C6 in it, for a 5.9L Cummins and NV4500 5 speed. The I6 and C6 have been very reliable, but having seen over 100K miles since I bought the truck, the engine is starting to get tired. Perfect "excuse" to upgrade to an even stouter engine/trans combo. I expect to see well over 25 MPG after the swap, so that makes it even more appealing.
Old 12-29-2013, 12:29 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,726 Likes on 1,396 Posts
Originally Posted by Gary Lewis
The wheel well trim is aluminum. If you can get the dings out you could polish it and clear-coat it to preserve it. But if the dings don't come out you can get replacements from LMC, but they are stainless and are more like chrome.
What conclusions did we come to in a earlier thread we had on this? I have forgotten. I think in that thread I brought up the use of easy-off oven cleaner to get the anodize off the aluminum, and then polishing it. I know the aluminum trim on my 64ss has this anodize, it's a coating to protect the aluminum, but after many years it gives it the smokey white look. But once you take the anodize off, you can polish it up to look like chrome, but you have to keep after it since it's now raw aluminum. The oven cleaner idea is what the chevy guys use.
I know that thread had many replies and many different ideas,, I don't know if we came up with a good way to do this.
Old 12-29-2013, 12:35 PM
Franklin2's Avatar
Franklin2
Okay I think that fixed the pictures
I would not hesitate 5 seconds to use parts off the later truck and put them on the earlier one you want to keep.
About the rearend; You really only need the heavier rearend if you are going to be hauling something heavy with this truck. If you are going to fix this thing all up and just cruise with it, the original rearend will be fine. But if you like the idea of the heavier rearend, go ahead and put it in BUT, double check the gear ratios. You never know what you are going to end up with. Check the axle code on the door jamb of both trucks, and then post it up, we can figure out what ratio the rearends have, and what your intended use is. If the original semi-float rearend is a 3.08 or 3.55, and the heavier duty is a 4.10, you might not want to swap the rearend in. The 4.10 rearend will make the engine have very high rpms on the interstate. Just be sure of what's going to happen and your intended use before you do something major like that.
Old 12-29-2013, 12:51 PM
Rogue_Wulff
Good point about checking the axle ratios. If they are the same, or the full floater has higher gears, there is justification for the swap. But, if the current axle has higher gearing, and the truck isn't going to see a lot of heavy hauling, then it would be the better option.
Old 12-29-2013, 03:48 PM
FXDawg's Avatar
FXDawg
FXDawg is offline
I'll photograph both door jam stickers and post them.
Old 12-29-2013, 08:17 PM
garthneddy's Avatar
garthneddy
garthneddy is offline
Subscribed
Old 12-29-2013, 09:15 PM
bruno2's Avatar
bruno2
bruno2 is offline
(popcorn) waiting for pics of the door sticker.
Old 12-29-2013, 10:43 PM
Rogue_Wulff
Old 12-30-2013, 09:00 AM
ctubutis's Avatar
ctubutis
ctubutis is online now
Old 12-30-2013, 04:40 PM
FXDawg's Avatar
FXDawg
FXDawg is offline
well here it is...can't read anything...
Old 12-30-2013, 04:44 PM
FXDawg's Avatar
FXDawg
FXDawg is offline
she looks better already!!
Old 12-30-2013, 04:48 PM
FXDawg's Avatar
FXDawg
FXDawg is offline
Can anyone tell me what this white box is?
  #28
Old 12-30-2013, 04:53 PM
FXDawg's Avatar
FXDawg
FXDawg is offline
where would would guys buy suspension parts and what brand? I'm thinking new shocks and springs and new Ball joints and tie rod ends... and so it begins... "I might as well do XXX while I've got it apart..."
  #29
Old 12-30-2013, 05:07 PM
bruno2's Avatar
bruno2
bruno2 is offline
That's an ignition module. They are color coded around the area where the wires go in. So just any box wont work.
I cant see crap from the door sticker.
  #30
Old 12-30-2013, 05:11 PM
FXDawg's Avatar
FXDawg
FXDawg is offline
Yea there is nothing to see on the sticker... I can just make out what info is supposed to be there but anything for this truck is long since faded away... is there any other way to get that info? VIN maybe
Quick Reply: 1982 F250 Restoration just started - now with pics!
