steering column replacement.
Old Dec 30, 2013 | 03:43 PM
Daniel5.0's Avatar
Daniel5.0
No, the lock pawl is the metal tab on top that blocks the shifter tube from moving when the key is not turned. Likewise, it keeps you from removing the key before having it in Park. Since you are going to put the spare column in, I would rebuild your original on the bench and swap it back in when you have time later.
Old Jan 3, 2014 | 07:07 PM
Mr.Dilac7.3's Avatar
Mr.Dilac7.3
<iframe width="480" height="360" src="http://s967.photobucket.com/user/chadillac33/embed/slideshow/"></iframe>
Anybody know how to remove this plactic hanger that holds the shifter linkage onto the steering column?
Old Jan 3, 2014 | 07:29 PM
88LX5.0H's Avatar
88LX5.0H
I'm pretty sure it just slides out. It's been a while since I messed with any steering columns. I think it's just pushed into place so it should just push back out of the notched out part
Old Jan 3, 2014 | 07:38 PM
Daniel5.0's Avatar
Daniel5.0
I had trouble with that too. Not sure exactly how, but I slid a screwdriver in between the plastic and the bracket and released the clip.
17fordguy
Apr 7, 2015 01:23 PM
jimbo285
62
Nov 10, 2014 01:05 PM
Martin Broll
Jan 20, 2009 10:07 AM
JamesTaylor
Aerostar
Oct 18, 2003 10:52 PM
