05 EXPY 5.4 Running Rough
Old Dec 27, 2013 | 01:09 PM
blackhullpirate's Avatar
blackhullpirate
Good Afternoon All,
I've got an 05, 5.4L Expy XLT. I changed the plugs at 100K. I've put 6,000 on the clock since then. I recently had two codes pop up. 0303 and 0316, misfire cylinder 3, and multiple misfires <1000 rpm. I had a coil on hand (Borg-Warner brand), so I changed the coil first. Seemed to help for a brief period, but the codes came back. I then changed the plug (Autolite). It didn't look bad, but again, I had one on hand, so I changed it anyway. It ran well for about 150 miles but both codes came back. This morning, I moved the new coil and plug to cylinder 1 and vice versa with the gear from cylinder 1. The engine is still not running well, but I've got zero active codes. It stumbles while stopped, in gear (like at a red light or stop sign) and while in OD at low revs most severely. It is intermittent, or seems to be. It will go a few minutes and be fine, but then come back with a vengeance. When the engine is stumbling while driving, if I put my foot in it a little more, it seems to get better when the tranny downshifts. Any thoughts or ideas? Thanks all! Cheers
Old Dec 27, 2013 | 07:46 PM
blackhullpirate
Ignorance is Bliss
Well, I was not aware that the cylinder numbering convention was different from EVERY OTHER engine on the planet. Turns out I've been working on the wrong cylinder. We'll try again tomorrow.
Flyfisher98
2004 - 2008 F150
Dec 26, 2017 08:39 AM
peakay
Modular V8 (4.6L, 5.4L)
Mar 25, 2013 04:34 PM
