Hello
Old Dec 26, 2013 | 11:21 PM
fordnoobe's Avatar
fordnoobe
Hello
Hi i am new here, recently purchased older f250 SD so i am looking whats out there for ford owners. Any way glad to be here!
I do have a litle problem with my ford and i am not sure where to post it yet so if some one can direct me to it that would be great.
Lil about my problem: Got a 02 F250 SD with broken tail lamp assembly, so i decided instead of buying OEM tail light i got a clear lens led set for really cheap but now the problem. It don't come with the LED's (but i did know that) so i got a new led bulbs for it and i know i will need led compatible flasher (already got it but didn't install it yet) because when i install the led bulbs in to the OEM taillights only the brake and turn signal portion works fine but not the parking/ running portion. I even try to run a wire directly from the wire harness to the bulb to make sure its not the bulb socket and still nothing. I did get the low voltage to light up from the brake signal so i know the light bulb works fine but i still cant get the parking/running to work on the taillights.
does any one have any ideas or experience with this? Nothing else seems to be effected by this problem, the front parking markers still work with or with out the LEDs in back
Thanks for any help
Jiri
Last edited by fordnoobe; Dec 26, 2013 at 11:36 PM. Reason: not sure where should i post the addition yet
Old Dec 27, 2013 | 10:29 AM
2ndStroke's Avatar
2ndStroke
Welcome to FTE
I used some led tail light in my f150, the resistors were built in. Can you just install the stock bulbs into the light??
Old Dec 27, 2013 | 08:14 PM
ATV PRO #11's Avatar
ATV PRO #11
Welcome aboard!!
carid
Vendor Specials, Discounts, Product Announcements & Group Buys
Apr 5, 2018 07:09 AM
BrianA
Apr 16, 2004 05:49 PM
