Is a v10 excursion right for me?
Old Dec 27, 2013 | 11:11 AM
EXv10's Avatar
EXv10
Originally Posted by fordboy67
You just need to be honest about your needs. If you are going to tow a lot get a diesel. If you are only towing occasionally a v-10 will more than fill your needs. Some guys are just diesel fans and no matter the application, only a diesel will do. Much the same way some guys, myself included, have to have 4wd. It just boils down to personal preference.
This would be my assessment also.
Old Dec 27, 2013 | 11:12 AM
EXv10's Avatar
EXv10
This would be my assessment also. (one of the best posts I have seen in here.)
Old Dec 27, 2013 | 03:48 PM
PROSTOCK's Avatar
PROSTOCK
Originally Posted by sccamper
Ive got an 01 V10 2wd. It got 9.4 mpg (hand calculated) towing to Orlando and back last month. Camper is 30 foot and weighs 6000 ready to camp. I kept the speed around 70. We havnt made a trip with the campers in the NC mountains yet but it did great in the SC mountains. It got 14 mpg on a trip to Wesser NC a few weeks ago with nothing in tow. 11 around town. I read a lot of post from folks towing 9000 plus pound camper with no problems, many have made mods to help towing. Towing with 6000 lb camper is great with no mods at all. We do use a weight distribution hitch and sway bar.
These agree with my assessment also.
Old Dec 27, 2013 | 04:06 PM
Snowseeker's Avatar
Snowseeker
My 2wd 7.3 X gets anywhere between 13.5-14.5mpg pulling both trailers in my sig.
Old Dec 28, 2013 | 04:04 AM
WE3ZS's Avatar
WE3ZS
I tow fairly heavy (9500lbs) with my V-10 EX, I have made several changes to the EX to improve my towing performance with long pulls following nearly every mod. The new heavier springs made the biggest improvement in ride quality, handling and comfort with the trailer in tow. The new deeper gears (from stock 3.73 to 4.88) made the biggest improvement in climbing grades and towing mileage. We have pulled through every Eastern state except FL and VT, and I have no complaints in it's hill pulling abilities. Our trip through TN, KY, VA, WV and PA was a good test of it's hill climbing strength, was able to maintain 60MPH to the top of the hills without having to floor it with very few exceptions. On the flat with the new 4.88 gears it will hold OD very well and that really helps the MPGs, we got 9MPG pulling North on I-95 from Savannah to Philly and it didn't drop out of OD once on that trip. On prior trips with the 3.73 gears over the same route we saw 7 to 7.5MPG.
Old Dec 28, 2013 | 12:03 PM
DmanNC's Avatar
DmanNC
Thanks guys for all the great info. I am going to look at an 2003 ex for 4x4 6.8 125,000 miles. They swear they are going to make me a deal fo a lifetime. Wish me luck.
Old Dec 28, 2013 | 11:22 PM
icentropy's Avatar
icentropy
I've been driving my v10 for about a year and a half now. We live in northern WA at elevation so the gas is a blessing for heat and lack of a engine block heater. It's nice to know it'll turn on and the fuel won't gel no matter what.
On the negative is always the MPG. It's terrible. Even for a 4ton pig it's still bad. To add insult to injury, we live at 4K feet elevation and every drive involves going up/down the mountain at least 2K feet (usually 3K feet) elevation change so we average 7-9mpg not towing.
If you can live with single digit MPG then a V10 Excursion is simply awesome. If you can't then look elsewhere, any modern diesel can get better MPGs, Hell a 4dr duramax truck will get in the 20s i believe. If you can live with 4-5 seats then that's a great tow rig. We picked up the Ex simply cause we like space and i got it for $5K or a bit under if i remember right. For a good running, clean Ex.....who can say no to $5k! I figure the money saved should pay for my gas for a few years...
Old Dec 28, 2013 | 11:54 PM
VQT's Avatar
VQT
Originally Posted by AlaskanEx
i'll say this, the cash saved on the V10 will buy ALOT of gas for MANY miles!
(just speaking of up front buy-in costs)
I begin to think AlaskanEx has a very valid point on gas vs 6.0 L diesel. Even with the money I save on labor since we do the work ourselves, I am up to about $1,500 on diesel parts to get it running. I don't know how much more I have to spend to keep it running.
The only thing I am concern now is getting stuck thousand of miles from home and be at the mercy of the dealer or a diesel shop which take days to fix.
Old Dec 29, 2013 | 08:17 AM
LivingLarge's Avatar
LivingLarge
Your scaring me, stop please
Old Dec 29, 2013 | 09:05 AM
Snowseeker's Avatar
Snowseeker
I can't wait to have the chance to be stranded with my 6.0 somewhere else besides my driveway.
Old Dec 29, 2013 | 09:05 PM
VQT's Avatar
VQT
Just got back from a thousand plus miles round trip with a rough idle ( something wrong with injectors #2 and #8). Glad that it didn't stranded me.
Working on taking the driver side valve cove off and the injectors to see what's wrong the next few days.
Old Dec 29, 2013 | 09:13 PM
VQT's Avatar
VQT
Are you serious? I do not want to work on the truck far away from home.
Old Dec 30, 2013 | 01:16 AM
  #28
rockcrawler_101's Avatar
rockcrawler_101
I Used to have a 7.3l super duty and now have a v10 excursion. I Love the v10 its a great motor with the 4.30 gears. I had my 7.3l hopped up some but nothing extreme. the v10 pulls amazingly you just got to be willing to rev it up. I just went up to Washington from California to get a tractor. I towed my 3000 pound trailer up there and got 12.5 mpg and when i got the tractor i was towing 10000 pounds and got 9.5 mpg for the trip. I only slowed once below 55 mph towing the hills and that was because of fog. I pulled every hill with no problems. If you do get an excursion be prepared to changed the front leafs over to super duty ones and get some sway bars and air bags in the back or RAS because the suspension on these things stock is just scary!
Old Dec 30, 2013 | 01:28 AM
  #29
kermmydog's Avatar
kermmydog
I pull with a V10 Dodge. Gas out here is $.70 cheaper than diesel. Personally I think a diesel is more expensive in the maintenance dept. Unless your towing heavy loads non stop a diesel doesn't pay as far as I'm concerned.
The V10 will work just fine & would be my preference.
That is my bias opinion.
Old Dec 30, 2013 | 01:31 AM
  #30
Mr.Nobody's Avatar
Mr.Nobody
I have an f-250 with the 6.9idi... So I'm wondering what could be wrong with your idi that you need a v-10 Ex? I just keep fixing mine, runs great, pulls strong, and gets great fuel economy.
I also have a 6l Ex (sig pic) and I get 13-14 pulling my 30 ft Airstream through the Cascade Mountains. Not so much about the 6l for me, I really like the transmission for towing.
All that said I guess I'm in the fix the idi camp.
