1997 hard start when cold....
Old Dec 25, 2013 | 08:35 PM
Serenity06's Avatar
Serenity06
For Christmas i sold my gas guzzling 95 GMC 2500 4x4 and bought a 1997 F250 7.3 diesel 2wd. Not happy about the 2wd but i'll live. lol
I bought the truck from my stepfather who has always plugged it in even durning the day in the winter. Its hard starting and sometimes wont start if you dont. His theory is that the older ford diesels are just like that.
What can i do to fix that? I cant always plug it in where it gets parked for hours...
Old Dec 25, 2013 | 08:43 PM
osu711's Avatar
osu711
Well his theroy is a little off,
These trucks should start if your glowplugs are working correctly, which in this case it doesnt sound like it is. Is your GPR working
Welcome to the forum
Old Dec 25, 2013 | 08:49 PM
guthrie&co's Avatar
guthrie&co
I have a 96 250 with 275k on the clock and it is hard to start at times. I know I need to get the GPR replaced along with the glow plugs. I see white smoke when it starts up. Look for the white smoke with yours.
Old Dec 25, 2013 | 08:52 PM
Serenity06's Avatar
Serenity06
Thats what i thought. I have absolutely no clue.... I honestly know nothing about diesels. Ok i know enough to drive it I guess. lol. I bought it because I rodeo and will eventually be moving from Colorado to Washington with 3 horses.
Where can i have the relay and glow plugs checked out without spending an arm and a leg?
Old Dec 25, 2013 | 08:55 PM
Serenity06's Avatar
Serenity06
I'll look. right now its hard to differentiate between white smoke with it being so cold. its 20* or below when starting it in the morning and almost the same when i leave work at night.
Old Dec 25, 2013 | 09:00 PM
guthrie&co's Avatar
guthrie&co
Oh you would know if you had white smoke. It would be thick and somewhat clear up after start up. You should be able to take it to a diesel shop and they can check it unless you are handy with an ohm meter. Some of the others can tell you how to check/read it. Crome to think of it I found a video on YouTube jut the other day on how to check it.
Old Dec 25, 2013 | 09:01 PM
guthrie&co's Avatar
guthrie&co
Here you go
Old Dec 25, 2013 | 09:06 PM
Serenity06's Avatar
Serenity06
I'm far from being a mechanic. lol. I dont have the meter and cant ask my stepfather so i'll have to take it somewhere.... I'll make some calls tomorrow Maybe i can find a friend with one.... I've never seen anyone have to plug one in during the day so i definitely knew his therory had to be stretched....
Old Dec 25, 2013 | 09:10 PM
guthrie&co's Avatar
guthrie&co
Where are you located?
Old Dec 25, 2013 | 09:16 PM
Serenity06's Avatar
Serenity06
I'm on the border of Co and Ks.
Old Dec 25, 2013 | 09:17 PM
guthrie&co's Avatar
guthrie&co
Never mind. I was going to suggest Clark Tire.
Old Dec 26, 2013 | 05:42 AM
427 fordman's Avatar
427 fordman
Buy yourself a cheap ohm meter and you can test them yourself. It's really quite easy, and I am extremely electronically challenged..
If you get one, let us know and we can tell you the steps to test the glow plugs and gpr.
Old Dec 26, 2013 | 06:00 AM
BEEMAC's Avatar
BEEMAC
Even on the coldest mornings you shouldn't have to have your truck plugged in more than 20 minutes. Block heaters work extremely well and waste a huge amount of electricity.
Old Dec 26, 2013 | 12:11 PM
Serenity06's Avatar
Serenity06
I'll look into those meters.
As of right now i was told to plug it in all night and while im at work... If i could fix that, that would be great!
Old Dec 26, 2013 | 04:54 PM
427 fordman
Block heaters do use a lot of electricity, but 20 minutes isn't near long enough. If you plug it in on a timer for about 3 hours it works well.
A cheap 10-15 dollar ohm meter will do what you need to do here.
