Prolonged Cold Start
Old Dec 25, 2013 | 05:00 AM
BigJohn61's Avatar
BigJohn61
Hello All,
I Love this site there is so much useful information and knowledge, need a little more please...
Back about a year or so ago I had to do an EGR Cooler delete, I thought I was very careful when I replaced all the O-rings and gaskets. Apparently I must have pinched something or installed a ring wrong. From what I've been able to surmise when I first start my '06 Super-Duty there is about a 5-10 second delay before the engine starts. From what I've been able to learn the problem is being cause due to the oil draining back down into the reservoir. I have no idea where to begin to start looking to be able to fix this short of taking it to a shop, which I dread because I trust no one to be accountable and do quality work.
Any help would be greatly appreciated or a good mechanic in the Zebulon,NC area
Thanks Y'all,
BigJohn
Old Dec 25, 2013 | 06:20 AM
mustang_309's Avatar
mustang_309
Did this problem start after your EGR delete? Do you use OEM oil and fuel filters and OEM oil filter cap? Do you have any gauges that read live data like scan gauge II or one of the smartphone apps like dashboss for IOS devices or torque pro for android? Does it start normally after it is warmed up?
Old Dec 25, 2013 | 10:34 AM
BigJohn61's Avatar
BigJohn61
everything is still stock haven't been able to upgrade anything, always OEM everything, usually starts fine after warm-up
Old Dec 25, 2013 | 11:10 AM
mustang_309
I would try parking it nose down over night to see if that helps with the long crank, if it does its because the shaft seal on the HPOP is leaking allowing the HPO reservoir to empty.
Old Dec 26, 2013 | 06:24 PM
BigJohn61's Avatar
BigJohn61
I have noticed that parking it on a steep incline helps it start normally thanks I will look into that as a fix or at least a place to start.
BigJohn
RPM371
May 2, 2015 12:29 AM
wagoneer33
May 4, 2013 03:43 PM
eliwho
Feb 23, 2012 06:17 PM
LostMedic
Sep 6, 2010 11:38 AM
selmacpa
Feb 5, 2008 06:12 PM
