What to look for...
Old Dec 23, 2013 | 10:02 PM
jayjjcc's Avatar
jayjjcc
What to look for...
Thinking of getting a 2000 Expedition XLT with 150k miles... looks clean, has the 4.6L.
I'm familiar with the modular fords (own a V10 Excursion) and have owned 2 Crown Vics (1998 & 2005). I know of the plug blowouts, manifold studs... is the intake on the 2000 expy known for cracking and leaking coolant?
How are the trannys on these things? Are there any known issues with these vehicles I should look for?
He's asking $1400 for it so I know it's not mint...
Old Dec 24, 2013 | 08:22 AM
timbersteel's Avatar
timbersteel
My intake/coolant crack happened at 201,000 miles. Other than O2 sensors,alternator, starter, tires, its still running strong.
Check radiator core supports and trailing arms. Trailing arms suck if so equipped, so look closely.. look at color of tranny fluid, smell of it...
All I can think of
Old Dec 24, 2013 | 02:29 PM
developer's Avatar
developer
Make sure the heat works properly. If the blend door is broken or (worse) the heater core leaks or is clogged, you could be in for a lot of work. Look for corrosion on the rear trailing arms. If they break, you will drop the rear and drive shaft, most likely during a stop.
Also, on 4.6s, there was a problem with the deck on the blocks where a tiny raised area would allow oil to leak out and drip on the starter. You don't want to know what it takes to fix that...
Last edited by developer; Dec 24, 2013 at 02:31 PM. Reason: Forget to mention oil leak...
Macmathews
27
Jun 2, 2015 10:17 AM
kawkx500
Feb 18, 2011 08:12 PM
dfisherman
19
Jan 3, 2010 03:00 PM
Navdriver
13
Apr 19, 2007 02:20 PM
TX76F250
Feb 21, 2007 12:54 PM
