JoeInMalta
Old Dec 19, 2013 | 11:12 PM
JoeInMalta's Avatar
JoeInMalta
JoeInMalta
Hello Ford Truck enthusiasts,
A few months ago I rescued a 1979 Ford F150 from a field in Rexford. I'm hoping to return it to service but it needs a lot of work. It hasn't been run in at least 10 years so the first thing I need to do is determine the best way to do that without doing any harm to the engine. Any thoughts? If I can get it running, I'm prepared to do body work. New floors cab and bed.
Thanks for the read.
Old Dec 20, 2013 | 07:21 AM
glruff's Avatar
glruff
FTE Leadership Emeritus
Hi Joe, welcome to FTE.
You might get more help by posting you questions in one of the tech forms. Try here to start,.,https://www.ford-trucks.com/forums/f...splay.php?f=38
Also stop by the NY chapter and say hi to the local members here,,,,, https://www.ford-trucks.com/forums/f...splay.php?f=87
Glad to have you as a member!
Old Dec 20, 2013 | 09:23 AM
ATV PRO #11's Avatar
ATV PRO #11
Welcome aboard Joe!!
Old Dec 20, 2013 | 01:44 PM
1Aauto's Avatar
1Aauto
Former Vendor
Welcome to the site.
Old Dec 21, 2013 | 09:53 PM
r_reed's Avatar
r_reed
welcome, joe. don't i know you from somewhere? there should be plenty of threads here on waking up an engine. you may need a certain number of posts to be able to use the search. i'll see if i can do a search and link it on the thread fro you to read. dick r.
Old Dec 21, 2013 | 11:26 PM
JoeInMalta's Avatar
JoeInMalta
Thanks Dick, I need five posts to open more privileges. I've been looking around the site and as you probably know there's a learning curve. I'm surprised at the number of responses I've received already from my first posts.
Old Dec 22, 2013 | 08:09 AM
r_reed's Avatar
r_reed
if/when you are able to search, click on search, then click on advanced search. that way you can specify searching "title only" or "entire threads". if you don't do title only, you will get a million hits, one for every place your word appears in the thread. don't know how active the group is for your year truck. the '48-'56 group is very active with a large group of knowledgeable guys. if you find a topic that doesn't get much resp on your forum, try the '48-'56. this place can give you a winter's worth of fun reading. dick r.
Old Dec 22, 2013 | 11:13 PM
JoeInMalta's Avatar
JoeInMalta
searching advice
Thanks for that tidbit on searching!.
1rainey
New Member Introductions
Oct 3, 2013 08:14 AM
PinkNinja
Aug 15, 2010 02:14 PM
goofy239
Jul 16, 2009 09:30 AM
rmiller01
Nov 30, 2008 03:42 PM
slyfox2062
Mar 19, 2007 12:49 PM
