How to delete traction control?
Old Jul 30, 2014 | 12:21 PM
FORDTUF1's Avatar
FORDTUF1
I raced at the motocross track in Picayune, know it well but not much about the town.
We never played them in sports, Hancock North Central was as far north as we got.
Old Jul 30, 2014 | 01:11 PM
BlackBeest's Avatar
BlackBeest
double post..
Old Jul 30, 2014 | 01:17 PM
BlackBeest's Avatar
BlackBeest
Originally Posted by RigTrash601
Not being a smart a$$ here, but what would be the need to completely eliminate TCS?
For me, I find it an overly-sensitive and unneeded, and sometimes dangerous intrusion into what I'm trying to tell the truck to do.
So many times, mostly when I'm turning, in an attempt to merge into traffic, I'll clip a curb or a little patch of riff-raff or God forbid a reflector or two in the road, and that'd be right about the time the turbo comes online, and a tire starts to spin a little and wwwhhhHHOOOOAAAAA where'd my acceleration go? Small cars n trucks in my rearview suddenly getting big as my foot's welded to the floor and the turbo unspools and the truck falls on its face and just.....
No.Thank.You. I can drive just fine without your involvement, mr BCM....
Old Jul 30, 2014 | 01:47 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
In soft sand/mud is another example where you want lots of wheelspin.
Old Jul 31, 2014 | 12:34 PM
BlackBeest's Avatar
BlackBeest
Originally Posted by BigF350
You are right, sorry, got AdvanceTrac and TCS mixed up.
A- just to clear it up, your original post was correct, 4Lo did disable TCS and AdvanceTrac for me, I checked it yesterday.
The only reason I didn't catch it when I was pulling that truck outta the ditch was because I had already turned it off, habit, upon startup a few minutes prior.
Old Aug 2, 2014 | 12:07 AM
Dyzzle's Avatar
Dyzzle
I had one of my Ford Techs run one of my upfitter switches to a 5 way relay that will kill the abs ( which is needed to turn off tcs and advance track) but will still provide power to the e locker. Works very well. I don't use it when Im in 4lo because I dont feel the need to ever go that fast in low range. 4hi yes
Here is some pictures
Old Aug 2, 2014 | 03:31 PM
robinsonpowerstroke's Avatar
robinsonpowerstroke
That is an awesome idea! Do you happen to have a wiring schematic on how he did it for you?
Old Aug 2, 2014 | 11:26 PM
Dyzzle's Avatar
Dyzzle
I'll see what I can do. He definitely wired the relay into the correct pins. I think that's the hardest part. Finding ABS power and E-Locker and wiring it from there. I'll see if I can get a diagram
Old Aug 6, 2014 | 10:34 PM
FORDTUF1's Avatar
FORDTUF1
Schematics would be fantastic!!
A good description would work too.
Old Mar 11, 2024 | 06:08 PM
drymike66's Avatar
drymike66
Trailering
It is disabled in Low Range only I believe.
I think its off in reverse also
Old Mar 14, 2024 | 02:18 AM
Euroman's Avatar
Euroman
Which model year did this problem start? My 2015 switches off on the dashboard or in 4WD, and I’ve filled up the wheel arches with mud testing it.
79f250-523
2009 - 2014 F150
Sep 23, 2014 03:15 PM
FORDTUF1
6.7L Power Stroke Diesel
22
Jul 29, 2014 07:25 PM
cummins cowboy
59
Dec 28, 2012 09:50 PM
Orion_70
Oct 6, 2010 11:47 AM
