Help needed with some 223 stuff
Old Dec 23, 2013 | 10:45 PM
GB SISSON's Avatar
GB SISSON
But do they both have same 110" wheelbase chassis? The drive line from a f100 4 speed should work I'm thinking. And BTW, thanks so much Stu! The dipstick and gaskets arrived today. I'll check the oil tomorrow
Old Dec 24, 2013 | 09:21 AM
hiball3985's Avatar
hiball3985
The panel and the F100 are 110" I think a drive shaft from a pickup should work fine. I used a drive shaft from a pickup for my 3spd and it was an exactly the same so the 4spd should be too.
Old Dec 24, 2013 | 09:24 AM
GB SISSON's Avatar
GB SISSON
Thanks! I think I'll McGuyver one together and start searching for an original, or eek, open my wallet and have one built.......
Old Jan 20, 2014 | 07:48 PM
Maltman's Avatar
Maltman
does 8" to top of dipstick tube mean 8" to the "cap"?
Originally Posted by spurredon
By the way Gary, the OEM dipstick is about 13 3/4" long total. The top of the dipstick tube is 8" above the full mark and the add mark at the bottomof the operating region is 3/4" farther down. The original has an additional 1" below that which is tapered the last 3/8" or so. The remaining 4" are above the "stop", and are formed into a loop for gripping. You could of course just make sure it has five quarts in there and make a mark where the level hits the stick!
Old Jan 20, 2014 | 09:58 PM
GB SISSON's Avatar
GB SISSON
I will measure the one that Stu sent me on Wednesday. I'm heading off to zzzzzzzzzzzz land as I have to get up at 4:30 to catch the early ferry. My '92 f350 is waiting for an injector pump, so I'll be driving my '59 to Seattle and then back by noon to pick up almost 4000 lbs of beams to bring back to the island. That's a lot of weight for a pickup truck. I will take my camera. It is gonna be a tough grind when I get back to the island. It is very hilly here, but old fords are really, really tough trucks. The '59's frame looks like it belongs under a ton and a half.......
Old Jan 21, 2014 | 05:12 PM
spurredon's Avatar
spurredon
Your truck was a dually in a previous life wasn't it?
Old Jan 21, 2014 | 10:39 PM
GB SISSON's Avatar
GB SISSON
Yes, and I think the gvw is 9600. It now has a '92 sterling 10 1/4 rear axle fom an F350 dually pickup. The guy wasn't done with the beams so he only had half the weight for me. 2300 lbs. I did pick up a correct flywheel for my flathead v8 project I'm working on. I had to drive down the interstate to Seattle in the morning to make a delivery to a church we are doing restoration work on, then race back up here to two different stops and got back to the 3:05 ferry with one minute to spare. Actually I was two minutes late, but the ferry was running three minutes late. Was in the fast lane for the full hour of freeway travel, and passed a lot of surprised folks.... Pictures tomorrow after I get some sleep. zzzzzzzzz
Old Jan 22, 2014 | 12:52 PM
GB SISSON's Avatar
GB SISSON
Not sure of the speedometer error, (Chev tranny , cummins, '92 rear....), but I was keeping up with the fast lane. On I-5 that is 70 posted speed limit. For you hot rodders , that's nothing, but this has a 210 cu. in diesel with 120 hp, and a home-made driveshaft and front hubs. I thought it did ok for what it is, keeping in mind it probably had a top speed of 50 as built.
Old Jan 22, 2014 | 12:54 PM
GB SISSON's Avatar
GB SISSON
Just realized I have hijacked my own thread! This was about the 223! Shoulda started a new one.... 'Life in the fast lane'.......
Old Jan 22, 2014 | 05:54 PM
spurredon's Avatar
spurredon
Looks like "Frankenfridge", did awsome!
chipmonkey
Oct 17, 2014 10:12 PM
tcoates
Mar 31, 2014 11:20 PM
vettes2
Mar 19, 2007 04:17 PM
marilyn
Dec 11, 2004 11:46 PM
fordman_302
Sep 24, 2003 10:12 AM
