Bed wood edges
Old Dec 17, 2013 | 10:14 AM
jrockdiddy's Avatar
jrockdiddy
Bed wood edges
I would like to cut my own bed wood and use a router to do the edges. Is the router the appropriate tool and what bits do I need?
Old Dec 17, 2013 | 10:38 AM
Jasonnoel's Avatar
Jasonnoel
You can use a router and need to order a slot cutting bit with bearing. It's not to hard. I have a shaper set up at my shop with a power feeder that makes it a lot easier and precise.
Old Dec 17, 2013 | 10:52 AM
49f3dls's Avatar
49f3dls
I'm not very good with wood but I put my router on a router table with a fence. then put a board down on the edge far away from the blade. This gave my boards a slant on the cut. The cut is a little deeper on the edge of the board than toward the center. Hopefully this will keep water from just sitting in the groove. I took my time and it looks OK so far. It wasn't hard just takes time. Now the rest of the sanding and finishing will have to wait for better weather. Good luck, Have fun.
Old Dec 17, 2013 | 11:19 AM
Wayne Waldrep's Avatar
Wayne Waldrep
You'll want to use a "straight plunge" router bit.
I used a fence (flat edge) at the right distance to do my main edge then just ran it out to clear the excess. You can kinda see in these pics the routed area on each edge. Sorry that's the only pic I can find.
Finished up nicely...
Good luck. Just ask if ya need anything else. We'll be glad to help.
Old Dec 17, 2013 | 04:10 PM
jrockdiddy's Avatar
jrockdiddy
Wayne, so do you have to use a router table?
Old Dec 17, 2013 | 04:22 PM
Jasonnoel's Avatar
Jasonnoel
Bring over you wood pieces over to my shop and it will take 15 min to run through my shaper when you're ready. Much cleaner cut than a little router.
Old Dec 17, 2013 | 06:05 PM
jrockdiddy's Avatar
jrockdiddy
Jasonnoel- deal. I'll text u soon
Old Dec 17, 2013 | 06:14 PM
abe's Avatar
abe
Here is a similar question about my 70 F350. The PO fixed up the dump bed by replacing the original bed floor with 2x6's and 2x8's. They are tight side by side and I think there should be a gap between them for expansion. I want to put 12 foot bed strips between the boards also.
My thought was this. Use a router to cut a gap between the boards and then use another bit to cut a rabbet for the skid strips. I think I would have to screw a board down to serve as a guide for the router.
Is all this feasible and practical and doable?
Old Dec 17, 2013 | 07:04 PM
Wayne Waldrep
No table used but I'd take Jason up on that deal as well. Great offer!
Old Dec 17, 2013 | 09:14 PM
smallello's Avatar
smallello
Are we there yet?
Wayne, that looks really nice! What kind of wood is that? Also, how wide are the boards?
Old Dec 18, 2013 | 04:10 AM
Wayne Waldrep
Thanks. It's just select grade pine. I ordered it from Lowes. The boards are 10" wide. I wanted a wider board and a lighter color. All I did was multiple coats of spar varnish that's just clear. No real color added.
centralNH
Apr 23, 2014 09:20 AM
greystreak92
1978 - 1996 Big Bronco
Jul 24, 2013 11:02 PM
Greg5OH
Dec 16, 2012 06:54 AM
99hosss
Oct 23, 2011 08:54 PM
