Rebuild
Old Jun 13, 2002 | 03:55 PM
mike03's Avatar
mike03
Rebuild
I have a question for you boys how much do you think it would cost to have a mazda 5 speed rebuilt and a 300 inline 6 individual prices perferably? i have 206000 miles on it and the motor still has alot of torque but it just uses more oil then what it should and the tranny when i let off the gas goin 20 i get a little jolt and i am thinkin its play in the tranny but i dont know? tell me what you think!
Mike
89 f150 300 5 speed 3.55 rearend long box w/ bull *****
Old Jun 13, 2002 | 04:40 PM
rusty9's Avatar
rusty9
Rebuild
>Mike
I think you could try a little heavier oil and have a look at your u-joints. you may not have do all that work. cost wise i am sure it will be a few thousand dollars for both. can't help you with exact numbers - haven't done mine yet cause i am only at 160,000 miles.
Old Jun 13, 2002 | 10:40 PM
Ford Truck Racer's Avatar
Ford Truck Racer
Rebuild
Mechanic told me that M5OD run a little light on the ATF fluid. It's not as thick as needed so you will get gear wear early. I'm running straight 30 weight motor oil in mine (Ford recommends in heavy duty apps) and it helps it alot. But run a Synthetic if possible cause dino oil will bind until warm on real cold days.
90 F-150 302 M5OD and 3.55's
Old Jun 14, 2002 | 08:34 AM
mike03's Avatar
mike03
Rebuild
Okay I had all new u-joints put in about 3 months ago so they still should be good. I am running 10w 40 in my engine now. So tell me what I should run in it. I want this motor to last as long as possible
what kind of tranny fluid did you tell me to use?
Thanks a bunch guys
Mike
Old Jun 14, 2002 | 12:18 PM
winfordr's Avatar
winfordr
Rebuild
