6.0l code
Old Dec 14, 2013 | 06:22 PM
Mcrafty1's Avatar
Mcrafty1
6.0l code
Installed my new bluespring upgrade today........when I started my truck after cycling the key a couple of times it started fine but the check engine light wouldn't go off, so I run the scan tool and it showed a PO113, I cleared the code the light went off and all seems well. My question is does anyone know what the code is for? or can anyone point me in the right direction for the codes? Thanks for any help. I might add that I did remove my air cleaner assembly to do the upgrade and reinstalled it and double checked the connections that I unplugged to do the swap. Also the tuck that I did this on is the truck in my sig.
Old Dec 14, 2013 | 06:34 PM
BLADE35's Avatar
BLADE35
P0113 IAT Intake Air Temperature Circuit High Input Short to voltage, signal circuit open, IAT sensor
So you must have Turned the Key on with it Unhooked at some point??
Maybe a Bad Connect and wiggled this is the Sensor at the AIr Cleaner
Old Dec 14, 2013 | 06:39 PM
BLADE35's Avatar
BLADE35
Its continuous monitor so it would already turn back on if you really had a Problem Unless its an Intermittened problem
Old Dec 14, 2013 | 06:41 PM
Mcrafty1's Avatar
Mcrafty1
Ok, I did a search after my OP (that's how I roll, lol I know, I know but I am a slow learner), and this is what I found...........P0113 - Intake Air Temperature (IAT) Sensor 1 Circuit High. Can anyone tell me the possible cause for this and if just unplugging it when I removed the air cleaner assembly and reinstalling it and plugging it back in would have caused this? As I stated in my OP I found the code with my SGII and cleared it and have since driven the truck about 70 miles and it seem fine. PS I also drove the truck about 5 miles with the check engine light on before the scan/clear and it ran fine then too.
Old Dec 14, 2013 | 06:44 PM
Mcrafty1's Avatar
Mcrafty1
Thanks Benny, I did remove and reconnect the wires that I had to remove to do the other work so maybe I just didn't get a good connection the first time. I have run it some since this happened and it hasn't came back so I just watch it.
Old Dec 14, 2013 | 09:16 PM
BLADE35's Avatar
BLADE35
WELL if it does come back I have more info on its trigger
Old Dec 15, 2013 | 03:27 AM
Mcrafty1's Avatar
Mcrafty1
Ok, I'll let you know if it does come back on, Thanks for your help.
95F150SuperCab
Dec 30, 2011 05:49 PM
bradk
1997 - 2003 F150
Nov 9, 2005 08:22 PM
Peter94
1983 - 2012 Ranger & B-Series
Sep 2, 2004 07:30 AM
cotoole
1997 - 2003 F150
Dec 2, 2001 06:29 PM
chrisa
Aerostar
Aug 31, 2001 10:11 AM
