Need Help Hookin Up Tach
Old Jun 24, 2003 | 06:27 PM
Boss50's Avatar
Boss50
I have 2 tach's. I'm not sure which one works if any, but I still wanna try hooking them up. One of them only has 2 wires. A ground and a long tan-ish colored one. The other tach has 5 wires: a long green one, yellow, black, tan, and a short blue. I'm wondering why one has only 2 wires while the other has 5. And can someone tell me where each of the wires get hooked up to? I tried hooking up the one with 2 wires. Put one wire on the coil's positive wire, then tried grounding the other one only to get shocked...So I need some help Thanks
Old Jun 24, 2003 | 07:22 PM
ecarter50's Avatar
ecarter50
All the tach's I have seen are 4 wire.
red - positive with key on
black - ground
white - dash lights
green - negative side of the coil
Old Jun 24, 2003 | 07:24 PM
Boss50's Avatar
Boss50
What's up with my 5-wire one then?? Damn Hawk gauges......
Old Jun 24, 2003 | 07:35 PM
jeepin_ford's Avatar
jeepin_ford
I don't mean to hijack the thread but how do you tell which side of the coil is the negative side? That's all I need to figure out to be able to hook up my tach.
Old Jun 24, 2003 | 07:38 PM
Boss50's Avatar
Boss50
I think positive is the top wire. That is what you wanted to know right? My head isn't working and I can't think striaght right now. Milano cookies are getting to me......
Old Jun 24, 2003 | 09:59 PM
Mil1ion's Avatar
Mil1ion
You mean there isn't the word TACH on one of the connectors?
There might be a + & a -
Old Jun 25, 2003 | 08:35 AM
dagray3's Avatar
dagray3
I think my 86 tach only had 2 wires. There was a ground, and then a connection that went from the coil to the fuse box and then to the tach. I thought on all of our trucks the tach connect wire is dark green with yellow dots. I found mine on the driver's wheel well.
I do have the Haynes manual though, so I can check that and make sure for an 81.
if you want to, email me at dagray3@vt.edu
jp1251
15
Aug 13, 2014 10:37 PM
FarmerFrank
4 Cylinder Engines
Oct 19, 2010 08:01 PM
FarmerFrank
1978 - 1996 Big Bronco
Apr 5, 2010 03:30 AM
MintFord
1983 - 2012 Ranger & B-Series
Jan 19, 2007 04:05 PM
faroffthetrack
May 20, 2004 04:13 PM
