AC compressor Bracket
Old Jun 24, 2003 | 05:54 PM
5_labsownus's Avatar
5_labsownus
I am looking for an AC compressor bracket for a 300 I6 or and after market mount! Does any one know of one? Most I6’s around here don’t have them or they have been removed and pitched. Junk yards have not been much help!
Old Jun 25, 2003 | 12:25 AM
steve83's Avatar
steve83
What year is your truck and where is "around here"? I've seen some around HERE.
Old Jun 25, 2003 | 06:57 AM
jamesmonty's Avatar
jamesmonty
I have the complete acessory drive brackets I took off a 88 I-6 parts truck. Would let them go real cheap since I don't need them and would like to clear out the bed of my truck. Don't know if they would fit an older six, but it would be cool to switch one over to a serpintine delt drive. All you would need are the pullies.
Old Jun 25, 2003 | 07:09 AM
Omen's Avatar
Omen
Check here:
http://www.dennis-carpenter.com/
Or your local U wrench it/Scrap/Junk Yard.
Old Jun 25, 2003 | 08:55 AM
5_labsownus
It is a 1982 F-250 4X4. And around here is Western West Virginia (about 20 minutes from KY).
Old Jun 25, 2003 | 09:25 AM
5_labsownus
jamesmonty if you would e-mail me. we could talk about meeting sometime in the future. You are not that far away
rodneymcc@outdrs.net
Old Jun 25, 2003 | 10:13 AM
steve83's Avatar
steve83
I saw one at a junkyard 2 days ago with a York compressor on it. Do you know what compressor you have or plan on using?
PULL-A-PART AUTO PARTS, 966 W. MITCHELL RD, MEMPHIS, TN, 38109 901-785-9285
but I don't think they ship.
Old Jul 10, 2003 | 09:55 AM
Red/White and Ford's Avatar
Red/White and Ford
Try ackits.com. The mount and drive are new, and are made for rotary compressor (Sanden type) rather than the old York, which are not as efficient.
Old Jul 11, 2003 | 09:23 AM
steve83's Avatar
steve83
Maybe not as efficient, but they're known to be bulletproof, even when run without oil as air compressors.
Old Jul 11, 2003 | 11:22 PM
hconner3's Avatar
hconner3
Steve 83,
Where did you get that picture at, i am putting on board air on my 80 f 150, and need to get or fab an ac bracket for my eaton ac for air, similiar to york. Pretty much exactly the same as a york. Anyways i have the tank and all the plumbing done, all i need is a bracket and wiring(i'll do) to make it work. Any help would be appreciated
Is it off a truck with ac, modified, or fabbed or what
Thank-you
Harmon
Old Jul 12, 2003 | 12:19 AM
ecarter50's Avatar
ecarter50
The york compressor was used 73-82. Factory air and dealer installed air used different brackets. Factory had the compressor mounted at an angle on the 300 six. My 81 with dealer air had the compressor vertical. The picture above looks like 80-86 dealer air with horizontal mounting.
Old Jul 13, 2003 | 11:59 AM
hconner3's Avatar
hconner3
ECarter50
Any ideas as to where to start looking? Junkyard better, or should i try a dealer? YOur help has been appreciated
Harmon
Old Jul 13, 2003 | 12:08 PM
hconner3's Avatar
hconner3
ECarter50
I have a 1980 ford f150 4x4 with manual lockout hubs. I just repacked my front bearings, and they still seem to get hot. Do you know if you have had this same problem. I repacked them again a week later, and replaced the brake calipers bc they were cheap, and had been sticking 8 years ago, the last time the truck had run. I plan on using the truck for anything i need to, ie cross country treks if need be. And would like the peace of mind knowing the the bearings aren't going to sieze and tear off the wheel. I have done numerous other fixups to get this truck in good running condition, but these wheel bearings are giving me fits. One guy at oreilly's, a local auto parts store, told me that sometimes the rubber lines can fall apart from the inside and cause a sticking caliper, does this sound reasonable, it sorta does to me. Also my master cylinder is leaking a little bit, and that is the next thing on my list to replace, along with the rubber lines. I just wanted some input from someone who has experience with the same truck.
Harmon
Old Jul 13, 2003 | 04:44 PM
steve83's Avatar
steve83
Harmon
I snapped that pic in a U-Pull-It junkyard in Horn Lake, MS, on Mitchell Rd just W of Weaver Rd. I haven't asked them how much they want for it, but probably not much for both.
***OOOPS ! ! ! A sharp user just noticed my mistake. That's a 302 - not a 300. Sorry for the confusion.***
Old Jul 15, 2003 | 10:35 AM
Bikeitswift's Avatar
Bikeitswift
Well, in the anything's possible category, My 223 AC setup uses an Alan Grove Chevy six bracket set, but mixes the pieces up. Sanden doesn't sap HP, and is very efficient. Very compact, looks slick, and keeps me cool down here in South Texas! I have good picture if I could figure out how to post it, or email me at buellb@gvtc.com.
