factory jack?
Old Dec 12, 2013 | 08:57 PM
Ultraboy's Avatar
Ultraboy
factory jack?
what kind of jack does the Ex come with from the factory? Is is sufficient to raise up the suspension assuming you had a level sruface to work on?
Old Dec 12, 2013 | 09:17 PM
Misky6.0's Avatar
Misky6.0
Small bottle jack located in the pass side cubby near back of ex. I have NO intention of using it LOL.
I have 3.5 ton floor jack, 6 ton jack stands, and 12k lb ramps.. and AAA if on the road
Sent from my Sprint PC36100 using IB AutoGroup
Old Dec 12, 2013 | 09:20 PM
Ultraboy's Avatar
Ultraboy
But what I'm trying to figure out is if the factory jack will actually raise the Ex enough to take off a tire IN A PINCH
Old Dec 12, 2013 | 09:22 PM
LivingLarge's Avatar
LivingLarge
If you are at stock height with stock tires, yes.
Old Dec 12, 2013 | 09:37 PM
Apocalypse's Avatar
Apocalypse
Yes, has to to pass the government regulations
Old Dec 12, 2013 | 11:54 PM
Stewart_H's Avatar
Stewart_H
I'm not sure why you would think Ford would put an inadequate jack in the Ex, one that wouldn't allow the changing of a flat tire.
Did someone tell you it wouldn't work or something?
Stewart
Old Dec 13, 2013 | 12:03 AM
EXv10's Avatar
EXv10
Nah, they just put them in there for looks.
Old Dec 13, 2013 | 05:48 AM
GermanMike's Avatar
GermanMike
This isnt a car/truck jack. Its an axle lifter. Thats a huge difference.
This neat little thing was designed to
lift one side of your axle with the deflated tire. Nothing more - nothing less.
......and for this tiny job this toy will work properly.
If you want to lift the whole EX until it lift even the wheel from the ground you should use a 60" HiLift Jack under a massive homebrewed Rockslider.
Old Dec 13, 2013 | 09:03 AM
Apocalypse's Avatar
Apocalypse
Or just carry a 2 post lift with you
Old Dec 13, 2013 | 01:02 PM
jzellers's Avatar
jzellers
It does work well for what it is. I used mine to change a flat front tire at a rest area one time.
Old Dec 13, 2013 | 01:15 PM
VQT's Avatar
VQT
Remember to take one of this when you are on the road and need to change the Ex. flat tire.
Ingersoll Rand W7150-K1 1/2-Inch High-Torque Impactool Charger with Li-Ion Battery and Case Kit - Amazon.com Ingersoll Rand W7150-K1 1/2-Inch High-Torque Impactool Charger with Li-Ion Battery and Case Kit - Amazon.com
Old Dec 13, 2013 | 01:34 PM
X4The6-Pack's Avatar
X4The6-Pack
It will, I was so anxious to put the 2008 Super Duty wheels and tires on, I did it in my driveway. One tire at a time. What can I say? Where there is a will, there's a way!
Old Dec 13, 2013 | 05:00 PM
Misky6.0's Avatar
Misky6.0
Where there is a will, there are heirs to the estate too.
Old Dec 15, 2013 | 01:20 PM
X4The6-Pack
The estate doesn't consist of much ;o)
I do see what you're saying though. Given optimum conditions, I'd rather use a Hi-Lift jack any day. Didn't have mine handy at the time.
Old Dec 15, 2013 | 03:36 PM
Snowseeker's Avatar
Snowseeker
I have used the stock ford jacks (screw type they had forever) all the time for blowouts and whatnot. I had to use the X jack the first camping trip out to change a front tire. They work just fine. Even on our trucks with a load in the rear they lift without much problem. But they are tippy and small.
