Sponsored by: Real Truck
hanger vs. spring pack
Old Jun 24, 2003 | 04:34 PM
hubbardk's Avatar
hubbardk
I am going to lift the front of my vehicle (02 F-250 4WD crew V-10) to level it out. I'm not sure if I should use a hanger kit or replace the spring pack. Does anyone have any input in this matter? Ideally I'm looking for the most stable lift and I would like to maintain the same ride! I read some of the prev posts regarding the different types of hanger kits, but wasn't sure if hangers were better than new springs. My local 4wd shop recommended that I use the ProComp 2.5 spring pack.
Old Jun 24, 2003 | 04:47 PM
Donahoe's Avatar
Donahoe
Any time you use a full spring to gain ride hight you will increase spring rate. More spring rate give you more harshness in the ride.
Look at a 3" hanger system and run a bilstien shock... Your ride will improve over stock not go backwards.
Look at the EDGE
FABTECH
and RCD for Hanger kits
Old Jun 25, 2003 | 02:07 AM
RdBaron03's Avatar
RdBaron03
wat ever you do DO NOT BUY PROCOMP!!!! they are the worst springs ive ever ridden on!! i have a set of 4" procraps on my suburban and they are the biggest mistake ive ever made!!! talk about stiff, non flexy pieces of *****, these things are terrible!!!
