e4od torque converter
Old Jun 14, 2002 | 07:32 PM
daspud's Avatar
daspud
Post e4od torque converter
hello , what are the symptoms of a converter that sometimes will not unlock. how would it be repaired 94 bronco e4od , thanks jeff
Old Jun 14, 2002 | 08:29 PM
becica's Avatar
becica
when it comes to auto trans I found it always best to take it to someone who does nothing but transmissions
Old Jun 15, 2002 | 04:43 AM
GammaDriver's Avatar
GammaDriver
Old Jun 15, 2002 | 05:48 AM
Lightning2Fast's Avatar
Lightning2Fast
if your convertor will not unlock, your truck wuold wanna stall as you came to a stop. almost like leaving the clutch engaged at a stop light. basically the convertor clutch is either physically stuck or the solenoid has failed. eityer way youve gotta go into the trans to fix it.
