winter storage
Old Dec 7, 2013 | 07:07 PM
johnny yahoo's Avatar
johnny yahoo
winter storage
Anything I should do to the trailer that will sit out side for the winter? 18ft jeep hauler with wood deck. I taped over the plug with electrical tape and planning on covering it with a tarp. Anything else I should do to it?
Old Dec 7, 2013 | 07:33 PM
r2millers's Avatar
r2millers
You might un-weight on the tires, putting it up on blocks. Never hurts to protects the tires from sitting for months.
Weather permitting, re-grease the bearings before spring use.
Old Dec 7, 2013 | 08:14 PM
senix's Avatar
senix
pull the battery and check the level, fill if needed and either put it on a trickle charger or occasionally charge it during the winter.
If you have one on the trailer that is.
Old Dec 7, 2013 | 09:40 PM
BossGasser's Avatar
BossGasser
Cover the tires or take them off and store them in a shed or garage.
Old Dec 7, 2013 | 09:48 PM
jdadamsjr's Avatar
jdadamsjr
if just a utility trailer and not an rv that needs winterizing...
only thing I would suggest is tilt it enough to ensure runoff from the wood deck so it doesn't have anything sitting on it and rotting the lumber (even if it's treated it will go down in one witer ! don't ask me how I know )
Old Dec 11, 2013 | 11:40 AM
MisterCMK's Avatar
MisterCMK
Park it out of the way. I wouldn't bother horsing around with removing the tires or anything like that.
Also, you are better off leaving the connector upside down hanging from the tongue IMO. If you tape it up with electrical tape you may find it is corroded from condensation the next time you use it.x
Old Dec 19, 2013 | 04:24 PM
artfd's Avatar
artfd
Exclamation
The only way I know of to keep condensation out of electrical connectors is to put plenty of dielectric grease over them & around and inside their plastic caps - leave no space for air to get in or for water to run into.
My OEM trailer wiring connections on my F150 completely corroded away before I even tried to attach a trailer. I noticed this when the F150 was about 5 years ago, and its OEM plastic cap had been installed over the connectors the entire time.
My replacement connectors show no corrosion at all as long as I keep them slathered in dielectric grease.
Old Dec 19, 2013 | 04:27 PM
artfd's Avatar
artfd
Exclamation
I also suggest you "tent" any tarp you place over a flat area that you are trying to protect. Condensation always form on the underside of a stretched out tarp -- flat ones will then drip the condensation down over what you are trying to protect. A tented tarp will tend to have its condensation run down its underside & we can hope the runoff will fall somewhere more preferable to your interests.
Old Jan 1, 2014 | 11:15 AM
racsan's Avatar
racsan
for the trailer plug (i have a 6x10 box trailer, no brakes, std "flat-four" connector) i have a extra "car-end" connector i keep plugged in to the trailer light plug when its not in use, keep it coated with dielctric grease also, on the truck i have a extra trailer plug that is kept plugged into the truck when the trailer isnt hooked up, grease on those connections as well. so far ive never had a issue with my plug connections whenever ive needed the trailer. and even with a box trailer i keep the front jacked up higher than normal hook up height, lets the water run off. i dont bother with pulling the tires, i can see where that wouldnt be a bad idea, just have never done that.
Supercab
All Things Towing
Jan 24, 2011 10:06 AM
stevorino
All Things Towing
Jun 22, 2008 04:19 PM
ag-ford-4x4
All Things Towing
24
Jan 29, 2007 12:19 PM
EJL96PSD
All Things Towing
27
Jan 20, 2006 07:48 PM
Pig Pen Jr
All Things Towing
Mar 4, 2004 10:08 AM
