Limp passenger side.
Old Dec 5, 2013 | 07:11 PM
Cammjackson's Avatar
Cammjackson
I just replaced all front suspension parts on my truck because I lifted it another 2inches from the 6in it originally had. The passenger side is lower than the driver side height wise. Any suggestions on what the problem could be?
Old Dec 5, 2013 | 08:39 PM
Franklin2's Avatar
Franklin2
Take some measurements with a measuring tape. You should be able to compare sides and figure out if the difference is the springs or something else.
I will tell you something else that bites a lot of people. They lift the truck up to do a whole bunch of suspension work, and they tighten everything up while it's up in the air and out of wack. You need to leave all the suspension joints loose, let it down on the ground and bounce it up and down a couple of times, and then crawl under and tighten things up.
I know it's a pain without it being lifted up to work on it, but things can get in a bind if you tighten stuff up with it lifted in the air with no weight on the wheels.
Old Dec 5, 2013 | 09:45 PM
Cammjackson
Ok well exactly what parts are you talking about? I was thinking about just putting a cool spacer on the passenger side or a couple on each. I did the lift myself but I don't know why it is leaning.
msfprobass
May 23, 2006 12:15 PM
dallas lewis
1978 - 1996 Big Bronco
Dec 21, 2005 02:37 PM
javadude
Jun 21, 2005 03:08 PM
