Steering problems
Old Dec 3, 2013 | 07:57 PM
SEH43's Avatar
SEH43
Steering problems
I've got an 86, 6.9L, F250, 2wd. It has a small amount of play in the rebuilt steering gear, plus a smaller amount of play in the rag joint, total about 1-1/8" at the wheel. The problem is when it drifts to one side you pull a little in the wheel to correct, and nothing happens. You pull a little more and it will over correct and go the other way. I do this as gently as possible, but it is still an issue.
I have replaced the sway bar and radius arm bushings w/polly, had the wheels professionally aligned and the king pins and ball joints are in good shape. What I haven't done, and was trying to avoid, was replace the axle pivot bushings. These look good but are hard to inspect w/o removal.
My question is, what would be the most likely cause of this problem? I suspect the axle bushings, but would appreciate others input, before I tackle these. I am hoping some one else has had this issue, and has a solution.
Thanks in advance,
Old Dec 3, 2013 | 08:08 PM
airdale94's Avatar
airdale94
Pretty sure I read on another post that is the symptoms.
Old Dec 3, 2013 | 08:29 PM
Chevy_Eater's Avatar
Chevy_Eater
Yes, axle pivot bushing for sure! That's a hairy ride, you end up halfway into the oncoming traffic lane. My '69 F250 was like that when I bought it, made for a wild ride home.
Good news is it's not that hard to pull the axle off. The new bushing needs to be pushed in at a machine shop, but it's not expensive, Napa only charge me $15 to push the new busing in. (That's the labor, bushing was extra.)
Old Dec 3, 2013 | 08:34 PM
Chevy_Eater
As far as checking them, jack the truck up by the frame so the axle and spring have no tension on them and the wheel is just hanging. Grab the bottom of the wheel and pull out, if the bushing is bad you'll get a fair amount of play.
Or jack the truck up as described above, block it up for safety's sake, pull the axle pin bolt and pull the end of the axle down to where you can visually look at the bushing. If it's been driven like this for some time the bold may have some wear in it too causing it to hang while driving it out. Usually just twisting it until you get to the sweet spot to come out will work.
WillsF100
Jan 2, 2011 08:45 PM
mrfix71
Apr 15, 2010 05:06 PM
v8xploder
1978 - 1996 Big Bronco
Nov 9, 2008 11:31 PM
67f100
Feb 24, 2006 07:56 AM
mnm99
Apr 11, 2003 10:50 AM
