Sponsored by: Real Truck
Locating a vibration???
Old Dec 2, 2013 | 05:01 PM
sg2004's Avatar
sg2004
been trying to find the source of a vibration for a while now on my '04 F250 120k miles. Only happens starting from a stop and either turning left or right at moderate throttle as when I pull out of my driveway and stops as soon as you straighten the wheel. Doesn''t happen with the wheel straight starting from a stop. Hard to tell if it's from the front or back or the back but I and a few other people believe more so in the front. Front wheel bearings are good, upper and lower ball joints replaced about 10k miles ago. Front Ujoints had some play in them so I replaced both ujoints and all seals on both sides. Front tires had a little cupping on the inside - rotated the tires to the back. Everything appears tight. Snow coming soon and I don't want to break down while plowing in a storm. Any ideas???
Old Dec 2, 2013 | 05:08 PM
redford's Avatar
redford
FTE Leadership Emeritus
Is your truck 2WD or 4WD? What engine? What transmission? What color? (just kidding)
Where do you feel this vibration? In the steering wheel? The truck seat? The gas pedal? The radio volume ****?
Just a guess, but your symptoms sound to me like you are turning while a hub is locked. If your hubs are not locked, you may want to check them.
Old Dec 2, 2013 | 05:18 PM
sg2004's Avatar
sg2004
it's 4 wheel drive automatic and is vibrating when hubs are unlocked. I've reached under and turned the front drive shaft to make sure everything is unlocked. As I said its hard to figure where I 'm feeling the vibration the most - leaning towards the wheel
Old Dec 2, 2013 | 05:25 PM
Bigpipes 35's Avatar
Bigpipes 35
My bet is you have the same problem I do and mine is the Limited slip in the rear axle chattering on take off. I have tried adding more friction modifier with no change. In the spring I am going to drain the amsoil I have in there now and go with something like Mobil 1 which already has the modifier in it. You could either add more or change your fluid and see if that helps. If it doesn't help me it looks like I will have to take mine in and have the clutches rebuilt..
Old Dec 2, 2013 | 05:49 PM
sg2004's Avatar
sg2004
I know I replaced the rear diff fluid with Royal Purple and a finned cover maybe 30K-35K miles ago. I haven't noticed any leaking back there but thats a quick check. Never really though of the rear Limited Slip being a possiblity for this vibration?
Old Dec 2, 2013 | 05:55 PM
Bigpipes 35
Mine seams to do it on takeoff turning left or right and its worse when I am pulling my camper and the fluids warm..
Old Dec 2, 2013 | 07:25 PM
sg2004's Avatar
sg2004
whats the best way to check the rear ujoints,center bearing, and pinion bearing?
Old Dec 2, 2013 | 07:34 PM
hanna5120's Avatar
hanna5120
i had to replace the front wheel universal joints for the same problem on turns. later had to do all joints and carrier bearing on the drive shaft for vibration while accelerating.
Old Dec 8, 2013 | 01:35 PM
sg2004's Avatar
sg2004
ok so I added 2oz of Ford LSD additive, went out in the field and did some figure 8's to get it all mixed in. Felt it shuttering pretty good. Thought I'd drive it for a few days before adding more. I then drove some figure 8's on the asphat parking lot - felt good no shuttering. Today after doing some running around, again I felt the shuttering - from a stop and accelerating while turning only - not shuttering pulling out straight. Not sure how the LSD works but seems I have to be onto the gas pretty good while turning to get it to shutter. Doing circles on the asphalt I was hardly using any gas. So the question is do I keep adding additive a little a time to see if it goes away or is it possible something else may be wrong in the rear diff?
Old Dec 11, 2013 | 03:45 PM
wolfboy's Avatar
wolfboy
driveshafts
put truck in neutral wout parking brake (CHOCK WEELS) twist up,down,side to side and se if play in ujoionts yoll se movement especily in the cross the center support u have top drop you dont heveto take whole driveshaft out spin support if little movement but not binding cariers good still has grease if it spins real freely or if you here the berings (like when you clean out a bering with solvant and no grease) then the center suport is bad
Old Mar 12, 2014 | 11:15 AM
gunner192's Avatar
gunner192
I just started having the slight vibration when turning at slow speeds Left or right. Recently had the rear end serviced.
Old Apr 27, 2014 | 03:30 PM
Rick.charters's Avatar
Rick.charters
Want to bump this thread. Did anyone have any luck with new clutch packs or additives?
Old Apr 27, 2014 | 04:31 PM
jesse5's Avatar
jesse5
2 ideas. Lube the driveshaft splines with the special Ford grease.
Lower the driveshaft center support 1/8" at a time with washers or spacers and see if it helps.
Old Apr 27, 2014 | 05:01 PM
Rick.charters
Originally Posted by jesse5
2 ideas. Lube the driveshaft splines with the special Ford grease. Lower the driveshaft center support 1/8" at a time with washers or spacers and see if it helps.
So can you tell me what the drive shaft has to do with turning vibrations as described by the earlier posters?
Old Apr 27, 2014 | 08:04 PM
jesse5's Avatar
jesse5
You may disregard my idea if you like. It was only an TSB.
