Heavy tow today....
Old Jun 23, 2003 | 08:41 PM
walnutcreek's Avatar
walnutcreek
Thumbs up Heavy tow today....
My '93 F250 with 196,000 on the 7.3 diesel pulled 8,600 lbs up a steep grade for 5 miles....had to put it in low 4x4 to climb out of this valley. On the road though ran great and didn't use OD due to the load. It was a low-boy with an IHI trac-hoe if anyone cares. (Dug footers for the horse barn and a pond today).
Anyone else pull loads like this?
Oh, truck is registered for this kind of load.
Old Jun 23, 2003 | 09:42 PM
MountainHound's Avatar
MountainHound
Heavy tow today....
What kind of terrain were you on when you had to go 4lo? Good story-that's quite a load to pull uphill 5 miles regardless what engine you got!
Old Jun 24, 2003 | 02:55 PM
Wstrombe's Avatar
Wstrombe
Heavy tow today....
I'd appreciate knowing too: how steep was that grade? What was your gear ratio? (Not idle questions. I might find myself in the same position....)
Old Jun 24, 2003 | 04:40 PM
walnutcreek
Heavy tow today....
31 degrees and 4.10 gear ratio I think....gotta check it sometime, but I think I'm right given fuel mileage. Thanks a bunch for this question.smiling hear!! Where do you live, I'm in the mountains in NC.
Old Jun 25, 2003 | 10:13 AM
Wstrombe's Avatar
Wstrombe
Heavy tow today....
I'm on the left coast-- southern California. I have to pull about 9500 lbs over a fairly steep, long mountain grade. Then another mountain grade later on.
But-- and here I am breathing a sigh of relief-- it is nothing like 31 degrees!
Old Jun 25, 2003 | 01:34 PM
Colossus's Avatar
Colossus
Heavy tow today....
Yeah, I just pulled a 8500lb load with our 78 F250 4x2 460/C6 3:08 up a 30 degree hill. Hauled it real well for being so high geared.
