ID this wire please
Old Dec 1, 2013 | 09:10 PM
Scoop531's Avatar
Scoop531
ID this wire please
Dunno where this thing came from or what it's for
It's hanging off a harness under passenger side wiper are. It looks to run into an orange wire behind that splice clip
Another question behind the engine there are 2 metal vacuum lines running up from under the truck only 1 is plugged into the manifold should I find away to plug the second in
Old Dec 1, 2013 | 09:22 PM
fmc400's Avatar
fmc400
MSEE
That section of harness is too cut up to definitively tell. The clamp splice makes it all the more suspicious; it may even be a hack.
The dual-metal vacuum line is for the automatic transmission modulator valve. There is always one line that runs to manifold vacuum; the second typically runs to the same source as the EGR valve to maintain relatively constant vacuum to the modulator valve, with and without the EGR valve open. You really shouldn't be without the EGR system, but if you are anyway, you should be able to just plug the open metal line.
Old Dec 1, 2013 | 09:42 PM
Scoop531's Avatar
Scoop531
Yeah this truck was deff a hack job at one time
norfolknova
Jul 4, 2012 11:34 AM
rustyranger390
Jul 23, 2011 12:32 PM
bkohne1
May 9, 2010 07:45 PM
diane
Bronco II
May 9, 2004 08:12 AM
Hit Man X
Aug 16, 2003 01:53 PM
