I got the bad parts torn off my sled. It actually came apart fairly easily I ordered the new parts from heinens. That was a quick way to spend $150. Unfortunately the new parts won't be in until early next week.
I figured while I had the expansion pipe off I would replace the header gasket that is seeping a little bit, the springs and the exhaust donuts. The a-arm bushing and the heim joint were not cheap though.
might as well. Not much sense doing it twice. Especially since those aren't time consuming jobs. hopefully I will have the excursion back running and out of the garage so I can get the sleds in to go through them this weekend
