Storage question
Old Nov 30, 2013 | 11:05 AM
Brnfree's Avatar
Brnfree
Storage question
It's that time of year again, cold and rainy. Camping season is over and the RV pretty much sits (out of the weather under a hard cover) until spring.
At the end of the season I change the oil, check all the fluids, winterize the fresh water system, and generally try to take it out for a 30 mile run, weather permitting, about once per month.
Is running it up once per month a good practice? Any other tips or tricks for the long winter layover?
Thanks.
Old Nov 30, 2013 | 11:24 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You just warm it up to get the juices flowing?
Where are you located, i.e. how long and how cold a winter?
If it were me I would probably just fog it and bring the battery inside to put it on a tender, but I don't know your situation.
Old Nov 30, 2013 | 11:38 AM
Brnfree's Avatar
Brnfree
I'm in the Pacific NW and winters are probably mild by most standards. Mostly it rains a lot. Typical highs 40's to 50's and overnight lows in the 30's with occasional cold snaps into the mid-teens. Camping season ends in October and begins again in April.
I try to take it out and drive it for about 30 miles monthly to run some gas through it, get the juices (various fluids) flowing, and keep the seals and gaskets from drying out, not to mention "rotating" the tires in an effort to avoid flat spots...
Old Nov 30, 2013 | 11:43 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I now understand you don't have prolonged periods of sub zero weather.
Yes, I could see why it is a good plan to cook off any condensation that may form in the oil and roll the tires.
Old Nov 30, 2013 | 11:57 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Adding some fuel stabilizer to non-ethanol blended fuel is a good idea. Ethanol blends do not fare well to sitting, even for 2-3 months.
Going for a drive every few weeks is good for the trans (C6 does not like to sit unused) and rear axle (ring and pinion can rust in humid climates, like you describe), as well as the engine and brakes. Tires can not only flat spot, but start to decay from continuous contact with the moist ground. Not a good thing to discover on the highway......
Old Nov 30, 2013 | 12:25 PM
Franklin2's Avatar
Franklin2
I agree on the non-ethanol fuel. Southern States sells it here. Look to see if someone sells it in your area. It's a little bit higher in price, but won't go bad as quickly as the ethanol blend fuel, and you will get a couple more mpg with it so the price is a wash.
Old Dec 1, 2013 | 01:35 AM
Brnfree's Avatar
Brnfree
Thank you for the replies and suggestions.
X100 on the pure gas. Before ethanol (BE) I'd get around 10 mpg. Now I'm happy to get 9. I get clear gas for the boat, I'll have to see if they'll pump it into the truck.
I'm familiar with "Stabil". Are there any other fuel stabilizers to recommend?
Thanks again.
deck60
Jan 16, 2012 08:41 PM
kaboom10
Oil & Lubrication
18
Dec 12, 2008 07:12 PM
Fordrules
15
Jul 12, 2007 07:05 AM
C Mionske/Cook
Illinois Chapter
Aug 18, 2004 07:31 PM
jlande
Minnesota Chapter
Jan 24, 2003 06:32 PM
