I am currently having troubles with my cooling so i am upgrading to eletric fans and i have a couple of ? They are what is good cfm to be pulled accross the rad? I have located a black magic elec fan that pulls 2800 cfm, the other ? is I can get two fans for $150 less and use one as a puller and one as a pusher but they only create about 1200cfm each, will that be equivelant to the black magic fan?
I do alot of off roading where my fan is bearly moving low rpm and not enough to cool in hot weather and during rock crawling
that why i was thinking of going to electric fans
Keep the stock setup and go with a big aux pusher mounted in front then. Set it up to kick in at about 210F. Make sure your stock setup has a thermostatic fan, shroud, and is in good condition.
you might also try putting in a high flow water pump($80). i put one in on my 400 and have a 195* t-stat new fan cluch and had the rad rodded($65)and i'm running 200*-215* with the fan shroud.
Mil1ion is correct, the aftermarket units are worthless. While the stock flex fans work well the best setup is still the stock thermostatic clutch fan. Less noise and less power draw.
I would also say that electric fans are more trouble than they're worth. They just don't move enough air. You could get away with it if you set it up right, though.
Memorial day we went wheelin' and my cousin truck had nothing but problems. It was HOT and we were idling most of the time so that just made things worse. He has a chebby 350 with dual electric fans and the thing would overheat every 20 minutes or so. He'd shut it down but could never restart without a jump cuz the fans drained the battery. We had to carry a spare battery to swap in to make it through the day.
The problem he as is the electric fans don't cool fast enough, which makes them run ALL the time. His alternator is probably not rated to handle the fans either so the battery drains in no time.
Granted, it's a chebby, but I have since abandon the electric fan swap for mine after that.
I changed the stock 5 blade fan on my 79 F250 S/C (400) to an aftermarket clutch with an OEM 7 blade Ford fan. The temperature dropped 10 - 15 F depending on conditions. I also changed out the stock rad for a larger 460 rad.
I pull a 4500 # TT and the coolant temperature has never exceeded 205 F. It is a treat now, knowing I won't have any overheating problems.
Is there a bolt-on fan clutch for older ('75 302) 4 blade original fan? I was planning also a electric fan conversion, but for the opposite: my truck gets too cold during winter. But after reading this discussion, I'm considering a thermostatic clutch.
