Hi there, its good to get another Nor Cal. member. I was born and raised in SF and surrounding areas. You sure got a great deal on your truck. Welcome to the best site going.
Get some Acetone and mix it 50/50 with ATF. And a squirt bottle.
Use it as penetrating oil everywhere.
even pour some down the plug holes. That mix and a hot wrench for the rusty
bolts will make the job easier.
Take lots of pic's and document how she came apart.
Welcome on board . Good to see another 3/4 ton being saved . Looks very good to start out with but more pictures are required and a run down of your build plan .
