tranny not working
Old Nov 27, 2013 | 08:04 AM
therigwelder's Avatar
therigwelder
tranny not working
Bought a friends 95 f 350 7.3 powerstroke with an E4OD.truck just quit driving.none of the gears work,I tried 1st and 2 manually nothing works.the fluid is full ,red and doesn't smell burnt.the od light works but is not blinking a code.any ideas where to look for the problem?selonoid pack.maybe the valve body? Thanks
Old Nov 27, 2013 | 01:19 PM
therigwelder
Nobody has any ideas?
Old Nov 27, 2013 | 01:36 PM
danr1's Avatar
danr1
Safe to assume that applies to reverse too? didn't actually say but sounds like it....
Drop the pan, verify the shift linkage didn't fall apart, in other words verify moving the shift lever moves the gear selector down at the trans both externally and internally, and see if find any "spare pieces parts" laying in it large or small.
Also make sure the filter didn't fall off, and if not that it isn't clogged.
There is more but first must check it out look for any obvious reason.
Oh and if its a 4x4 make sure its not a simple as the TC just isn't in gear or other issue with it as in not the trans.
Old Nov 27, 2013 | 02:26 PM
strokinout's Avatar
strokinout
With this tranny, I just got finished having issues and all it was, was the connectors needed cleaning but the mlps on the side was going out. So, once I got the connectors cleaned I never had another issue with it except one. I found this problem out the hard way when I parked in the back yard which is hilly and went in the garage through the side door with the garage door still closed. It scared the crap out of me when it decided to roll into the garage door. Start by cleaning the connectors, check for codes and take a good look at the linkage on the side of the transmission on the driver's side to ensure it's working properly.
Old Nov 27, 2013 | 05:14 PM
rla2005's Avatar
rla2005
It would help everyone if you stick to one thread for the same issue:
https://www.ford-trucks.com/forums/1...anny-quit.html
https://www.ford-trucks.com/forums/1...ad-tranny.html
z31freakify
Dec 12, 2017 08:18 PM
bushnell1987
1997 - 2003 F150
Aug 17, 2012 09:46 AM
tubolove
Jun 9, 2008 04:50 PM
444in.ofgoodness
Mar 17, 2006 07:10 AM
Tom Cat
Sep 8, 2003 08:21 PM
