Hunting Trip
Tonight we reset the black maxx tire size trying to get it exact with GPS and its very close with 34" tire selected. I also changed the Low Boost Fuel from 3 to 0 figured that should also help on fuel economy. will still be running the HD300 tune on wild? or the highest level as that is what most say is best for mpg.
Now i know the higher the air pressure the better the mpg but id also like to have some "ride quality" the tires are 65max for 3195# each. the truck door tag says 65 front and rear for the 6k front and 6100 rear axle GAWR. now i was curious how heavy the front really was as we will be running "empty" except 4 guys and all the hunting gear. so tonight with full take of fuel the driver and one passenger we weighed right at 9k# with 5500 on the front and 3500 on the rear. wow i knew these trucks are heavy but that's a lot of weight on the front end of a near empty truck. i currently have the tires at 50psi all around but i think ill bump em up to 60 all around? maybe leave the rear at 50?
Just this last couple weeks ive done some maintenance on black Betty, both belts and tensioners, air filter, 5w40 t6 oil and filter (all ford parts) balanced all 4 tire and swapped front tires around as they had some pull. the tires balanced out very nicely except i have one wheel the is bent and needs replaced to if anyone has a deal on a cheap 20' KR let me know! i took a oil sample and sent it into Blackstone, first time using them so curious on what they have to say. Last 2 tanks of fuel i have been running some Howes meaner power kleaner and will change both fuel filters after that.
So pretty much just curios what you guys think on air pressure and which route ya think would yield best mpg. everyone says keep rpms under 2k,
Running at 70mph yields ~1850 rpm and 60mph ~1575rpm.
