Sponsored by: Real Truck
410 gears
Old Jun 23, 2003 | 10:32 AM
TXF250's Avatar
TXF250
Question 410 gears
I have up grated from an F150 302 V8 too 1994 Ford F250 4x4 7.3 turbo diesel. I like it all but one thing. The mileage I’m getting 12 to 13 mpg. The drive train has 410 gears. I’m looking at going to 373 gears. Has anyone done this? And what do I need to look out for? Is this going to mess with the transmission? What can I expect as for a gas mileage after I change the gear out. Or should I go to the 353 gears?
Old Jun 23, 2003 | 10:44 AM
jetjock16's Avatar
jetjock16
410 gears
much easier to just run 1-2" bigger tires that will put you in the 3.73 range
Old Jun 23, 2003 | 12:24 PM
TXF250's Avatar
TXF250
410 gears
already have 33" tires done know if I real what to go bigger than that. Ill have to bye new wheels 16.5 or 17. That one reson I wanted to know about changing gears.
Old Jun 23, 2003 | 12:48 PM
jbalestri's Avatar
jbalestri
410 gears
You're looking at a bit of money.
First off, 3.73 gears would be fine. My father in law has a 96 F250 'Stroker with 3.73 and auto. It pulls his 5th wheel and boat combination quite well and his mileage isn't too bad.
BUT, you have to change both the front and rear differentials. I do not recommend doing it yourself unless you do it for a living. There are some very critical measurements that if they are not correct, you will destroy the gears and more quickly.
As long as you do both differentials, you are fine. I do not know, but you may have to have the speedometer re-calibrated.
Old Jun 23, 2003 | 01:02 PM
Waxy's Avatar
Waxy
410 gears
The savings you might see in fuel mileage will never (well, not any time soon anyway) pay for the cost of changing the gears, especially if you have to do both axles.
Waxy
Old Jun 23, 2003 | 01:52 PM
jetjock16's Avatar
jetjock16
410 gears
ive done my own gears.. its a true job.. about 16 hours and many fine measurement tools required.. did not help gas mileage significantly(bout 1mpg increase) but really helped pulling power... you dont have to re-do anything to do with your speedo or trans... just pull the old ring gear off and slap the new one on.. thats the easy part... the hard part is pinion depth and ring backspacing.. its a job
Joshey93
Mar 7, 2014 11:22 PM
lefty319
Sep 11, 2013 08:57 AM
Farmall05
WTB - Parts & other
Mar 9, 2012 05:31 AM
BACKWOODS99
Jun 22, 2011 02:32 AM
sbechtold
Jan 25, 2008 12:53 PM
