Final Wheel Decision: FTE opinions please
Old 11-23-2013, 04:11 PM
Jesser02EX's Avatar
Jesser02EX
Jesser02EX is offline
I have a 2002 7.3 Excursion currently sporting 17" wheels on a small lift. The tires look a little small so I'm looking to pick up something different for the winter shoes… I've been looking for the '04 18" wheels without success. So I've found a few other options and I'd like your opinions.
Option 1: 2008 18" Factory rims
Option 2: 2010 18" Factory rims
Option 3: 2011 20" Factory rims
Option 4: 2002 16" Factories that I took off…
No pic needed, we all know what they look like, just wrap them in some big rubber.
I believe all of these options require HUB CENTRIC wheel spacers. What is the verdict on the use of spacers? I know this topic has been talked about over an over. But I'd really like to go with some ford factory rims, and I'd like bigger then the 17"s I have now. These options are all local and priced right from fellow FORD owners. The 20's looks awesome, but either set of 18"s are better priced and I know will look great.
Thought's, Opinion's, suggestion's… I'll take them all!
Old 11-23-2013, 05:10 PM
ATV PRO #11's Avatar
ATV PRO #11
ATV PRO #11 is offline
Personally I'd never use spacers for a set of rims.
If I was, i'd choose option 3. Just looking at the backspace offset you'd need a pretty big spacer to mount those with the proper offset.
IMHO i'd shop for some correct rims for your year. I believe the 05-06 and up had different axle widths.
Old 11-23-2013, 05:32 PM
usmcdaveII's Avatar
usmcdaveII
usmcdaveII is offline
IMO, I like option 1. Here is what I went with (Inspired by "Jolly Green Giant"). 2006 F250 OEM 20's with 1.5 inch hub centric spacers. I just put on Toyo Open Country MT's (295/65/20), and love it. Is your Excursion just a daily driver or do you haul/tow a considerable amount of weight?
Old 11-23-2013, 05:58 PM
Jesser02EX's Avatar
Jesser02EX
Brandon, I don't tow much if at all. I do go off road and use as a daily driver. Those wheels look awesome!
Old 11-23-2013, 06:06 PM
usmcdaveII's Avatar
usmcdaveII
Thanks, I personally do not have a problem with a daily driver and hub centric spacers. However, I have not ran them long. No bad experience so far. Others despise. I had a look in mind and went with it. If I towed heavy frequently, I may reconsider. Locally these wheels run about $600 on craigslist. Maybe option 5. Good luck.
Old 11-23-2013, 06:33 PM
Jesser02EX's Avatar
Jesser02EX
In 8 months I haven't seen a single set of 04's on CL here or even 05-06's...
Old 11-23-2013, 06:39 PM
usmcdaveII's Avatar
usmcdaveII
Really, I can probably get you a set reasonable. Problem is getting them to you. I will be glad to help, if I can.
Search Greenville, SC Atlanta, GA Charlotte, NC craigslist. Might could pick up local and ship to you. Just send PM with cell number.
Old 11-23-2013, 06:48 PM
usmcdaveII's Avatar
usmcdaveII
Of course, I do a quick search and nothing of interest shows up. I just bought the ones I have, and a friend just sold a set just like the ones I bought. I see a lot of aftermarket wheels, so where do the OEMs go?
Old 11-23-2013, 08:43 PM
Jesser02EX's Avatar
Jesser02EX
What is the correct "offset" I would be looking for in an aftermarket rim?
Old 11-23-2013, 09:00 PM
usmcdaveII's Avatar
usmcdaveII
I believe this to be correct. Stock 16x7 OEM wheels 4.5 inches b/s. All 05 and up ford 20 inch OEM rims are 8 inches wide with 6 inch b/s. This the reason I have 1.5 inch wheel spacers. I will try to get a picture to show down the side so you can see. Mine wheels and tires are still under the fenders. Tires come out to be 35.4 x 11.8 on a 20x8 rim. Didn't want to beat the paint off. Removed body armor and mud flaps.
Old 11-23-2013, 09:11 PM
Tofan's Avatar
Tofan
Tofan is offline
Wheels on the white X are nice, just not for me. Option 3 would be my pick to make it look great without going aftermarket. If you do go aftermarket, I would look at XD wheels, not rockstars, but another one. Let us know with pics which one you choose!
Old 11-24-2013, 03:02 PM
Restlesswildman's Avatar
Restlesswildman
Restlesswildman is offline
Hub spacers are not that bad if you use the hub centric ones. I would not recommend doing serious off roading with them.
The OEM take offs probably end up being scrapped. Have you tried ebay?
Old 11-25-2013, 06:42 AM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
Of the 3 choices offered, I like #2 best. I like having a little bit more sidewall on my tires than a lot of 20" options allow for, however Brandon's white EX above looks sweet with those 5 spoke 20"s (and thanks for the mention of my Giant!). There are a few different styles of 18" 5 spoke OEM rims available that would keep Brandons look and keep you in the slightly cheaper (mostly) 18" tire selection. I tow heavy a lot so I wanted to stay away from spacers and I got lucky with a set of the 04 18"s for a decent price. I just recently mounted some 35"s on them. Nitto Dura Grappler (Highway tread) 305/70R18E. Bad picture but it's the best I currently have.
Old 11-25-2013, 10:30 AM
Jesser02EX's Avatar
Jesser02EX
eBay is $300-$400 each for the 04 18" options. Thus I keep looking aftermarket.
Old 11-25-2013, 01:01 PM
carbon coupe's Avatar
carbon coupe
carbon coupe is offline
I like the '08 18" ers. Always a fan of the OEM choice. I know all 3 are but those are it.
Quick Reply: Final Wheel Decision: FTE opinions please
