Excursion 4x4 help
Old Nov 23, 2013 | 11:47 AM
krath043's Avatar
krath043
Excursion 4x4 help
If anyone can help me figure out what's wrong with my 4 wheel drive I'd really appreciate it.
Here is what I know:
When I jack up the front end and lock the hubs I can see some parts behind the wheel turning, when I unlock the hubs the parts behind the wheel don't turn. So that tells me the hubs are fine (atleast the manual lock is but I'm not worried about the vacuum part right now)
Any idea why my 4 wheel drive isn't working?
Old Nov 23, 2013 | 11:48 AM
krath043's Avatar
krath043
I forgot to mention
The light on the dash comes on saying it is in 4x4
Old Nov 23, 2013 | 12:00 PM
garryk6's Avatar
garryk6
If the light comes on, that usually means that the motor has turned and engaged the transfer case. If you don't have 4x4 with just the switch, try manually locking the hubs, and then see if you have 4x4. If you do the you have issues with the ESOF hubs. If you have the light and the hubs locked in, then I would think there are issues with the transfer case motor or the pinion in the differential.
Let us know what you find.
Garry
bldsoe318
Feb 8, 2016 09:34 PM
rustyruststang50
Feb 7, 2014 12:24 PM
bscirep
Dec 17, 2011 05:52 PM
lukedraper
1978 - 1996 Big Bronco
16
Oct 2, 2003 12:54 PM
brmann
Aug 14, 2001 08:16 AM
