intermittent trouble codes - need help
my truck has been runnin crappy for several months (rpm's fluctuate, stalling, shifting a little off). after replacing the pcv valve, egr valve, and speed sensor, i sucked it up and bough a code scanner and it came up with 122 (TPS), 173 (o2 sensor), 327 (egr), 452 (speed sensor). all the codes indicated that the circuits were below voltage.
i then cleared the codes out of the computer and took the truck for a spin around the block and it ran fine - no problems and then no new trouble codes showed up. so i seem to have some problem that comes and goes as it pleases, which is how the truck as been running lately.
when i glanced at the wiring diagrams they all seemed to be connected at some point so i am pretty sure that the same problem is causing all the codes. does anyone have any ideas for me??? i dont know if it is a bad circuit, a short or bad connection somewhere, or if my PCM is on the fritz. i am not so good with this electrical stuff.
any suggestions would be greatly appreciated.
brian
You did the right thing by disconnecting the battery and loosing the old codes. Did you have a "check engine light" on before as well? Anyway if you did, keep driving her until you see the light on. Then check it for codes and see what ones appear. Don't be too hasty in changing parts until you verify these codes. Remember some codes are created by other codes and are false. Your truck has common problems like TPS and EGR, especially egr sensor. Give it a try and let us know. By the way a badly needed tuneup can set codes as well, especially a restricted fuel filter.
