MPG on 6.0L Ex?
I have an F250 with the 6.0L and while not an Excursion it does weigh in just shy of 8000lbs empty with a half tank of fuel and me in it.
On summer fuel we normally see 14-14.5 city and and 18-19.5 freeway.
On winter fuel we normally see 13-13.5 city and 18 freeway.
Freeway mileage is about 68mph, just under 2k rpm. My 7.3L Excursion gets very similar results completely stock.
I have cat delete, magnaflow muffler and Innovative Aggressive Tow Tune, everything else is stock.
Hope that helps a bit.
Cheers
Cheers
Our 05 is very close to fastang50's. I just removed the turbo and cleaed it, so I will see if it helps.
when my truck was stock, with 3.73s, 4X4, stock (road use very mild tread michelin) tires, on relatively flat roads i would get 16-17mpg hand calculated. swapping to 285/75s dropped me 1-2mpg. my srl+ tune giving me about 400rwhp didnt seem to change my mileage any. except when i put my foot down goodbye anyone near me as well as fuel economy.
currently with my pretty aggressive 33s, my tune (and a slightly heavy foot) i get 15 mpg almost every single tank. if its all city i average 14 and can see 18 with almost full highway use. i have once, saw 24, but that was on a 1200km road trip all highway already warm engine, and a 2,000 foot elevation drop.
Yes the petal to the metal tends to lower the mpg...
But raises the excitement level!
Mixed around town driving 15-17, depending on if warmed up or not and how long a trip lasts. I am 2wd, and aren't in a race on the hiway...
Long hiway drives it skyrockets..
When i first got my ex three years ago i got 21 mpg driving fl to nc and return, hiway driving mostly 74-75 (on speedo) which is really 71-72 cruise most the way. Got 940 miles on 45.5 gal on one tank.
Cruising at 2050 rpms or so.
Had the bulletproof setup installed and mpg dropped 19-20, now cruising at 2250 rpms though, in hindsight, i believe forgot to tighten exhaust bolts...
Got ficm repaired w/atlas40 from ed, more response at tip in, not much change in mpg or rpms on highway, but found big exhaust leak at exhaust manifold to y-pipe.
Fixed leak couple weeks ago, drove 250 miles yesterday hiway same 74-75 on dash, noticed rpms back to 2050 and overhead showing 24.8 vs previous best of 21-22. The sg2 instantaneous mpg was vastly better than last months trip, so i am stoked.
I can hand calc once i return and fillup, but ficm tune and fixing exhaust leak sure has paid off to me.
My lieometer is generally within 1 mpg around town, and closer on my longer trips..
Sent from my Sprint PC36100 using IB AutoGroup
Depends...
Mine stock delivers 13-14 around town. Coming back from Amarillo when I bought it, it got 18.3 mpg cruising at 65-70. Modded, highest was 17.5 coming back from tech day in Yoakum.
It a depends on your strategy. My truck was unfortunate enough to be reflashed under warranty and was neutered.
I plan on giving the truck it's ***** back by having PHP roll back the strategy to a more desirable one and tune the FICM for Atlas 40. I'll have better throttle response and better power/fuel economy. Just waiting to hear back from PHP next week.
