Anyone notice location of EGT sensor on long bed?
Old 11-21-2013, 02:52 PM
golfmedik's Avatar
golfmedik
golfmedik is offline
I noticed this this morning while under my truck. The EGT sensor just after the DPF on my long bed dually is right under the open gap between the bed and the cab. Directly exposed to water falling and running down between the cab and bed. Wonder if that is a contributing factor to that one going bad???
Old 11-21-2013, 03:13 PM
senix's Avatar
senix
senix is online now
Received 1,470 Likes on 1,049 Posts
mine appears to me to be just under the bed of the truck, safe and out of the way.
Old 11-21-2013, 04:21 PM
BigF350's Avatar
BigF350
BigF350 is offline
It shouldn't - all those sensors should be tested for water resistance (they are all exposed to splash from the road anyway)
Old 11-21-2013, 10:43 PM
TRENT310's Avatar
TRENT310
TRENT310 is offline
The underside of the truck gets pummeled by everything and basically gets pressure washed when you drive through a rain storm. In light of those other situations, wouldn't worry about dripping water.
Old 11-22-2013, 10:49 AM
golfmedik's Avatar
golfmedik
Yeah I realize that, I was just trying to rationalize why that one was near that gap and wasn't at least protected by a shield of some sort.
Old 11-22-2013, 11:02 AM
senix's Avatar
senix
senix is online now
I suppose you could fab something if you desired. With my headache rack I think mine will be ok.
Debris would be my concern if anything.
Old 11-22-2013, 01:53 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
cause the exhaust engineers and the body engineers didn't see the intersection.
remember the caramo that you had to jack up the engine off the motor mounts to change the plugs?!..
Old 11-23-2013, 09:08 PM
golfmedik's Avatar
golfmedik
You can see in this pic what I am referring to. See the bed gap right above the sensors. Strange..I thought!
Thurter
2017+ Super Duty
05-12-2017 06:26 AM
SMLWinds
1999 to 2016 Super Duty
03-03-2015 03:27 PM
jda1961
2009 - 2014 F150
04-12-2009 02:29 AM
vtx1800
2004 - 2008 F150
08-08-2007 08:21 PM
samckernan
01-03-2004 09:25 AM
Quick Reply: Anyone notice location of EGT sensor on long bed?
