P or LT tires?
P tires have fewer belts in the sidewalls, hence the lower load capacity and softer ride.
LT tires have at least one more belt and a higher load rating, and thus a harsher ride.
I would stay with the recommendations on the sticker. If you want, you can drop the pressure 3-5psi and get a softer ride. If you have to haul anything, increase the pressure a little and you should be good to go.
If so, you need to go to the LT tires based on this.
Two tires gives you 3400 pounds. Minus the 2100 pounds of sand, leaves 1300 for the truck. Based on 60/40 weight ratio on a truck, that means your truck can only weigh 3200 pounds. I think it would weigh more than that.
You door stick will give you weights based on tire sizes. My 2003 Toyota RAV4 has LT tires on it and it only weighs 2200 pounds.
As far as geometry of suspension, that is two different beasts, at least the rear is. Your truck is solid axle, where as the Expl is independent. Also, the suspension in an Ex is made for comfort, in a truck it is designed for load capacity and travel and is harsher by nature.
I notice a difference between 45 psi and 60 psi in my truck. But I also run load E tires.
I had 31x9.5x15 BFG's on my old truck and they ran fine. I ran 35 psi in them, and it rode great.
LT tires will need less pressure, and if you drop the pressure in the Expl about 5 psi, your ride will soften out and should be about the same as passenger tires with the wear even.
I guess I should ask this, Tire Rack says that your tire should be 255/70R-16. Those have a load rating of 2100 pounds or so. What size do you have???
Any chance the tire shop you're getting them from would let you test ride the tires?
My theory, is always, the bigger, the better. I don't need load range E, but I run them just in case I do. I would hate to have a sub-standard tire and have a failure because I overloaded the truck.
I would recommend the larger tires and just drop your pressure. Your footprint will be larger, thus the lower pressure.
